03-05-2009, 13:52 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Huawei-T161L successfull unlocked COM4 [VCP0] selected module v1.63 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: E:\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090305-044117.B1E.bin loading data... data loaded reading eeprom-security... file saved: E:\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090305-044118.B1E.bin reading eeprom-complete... file saved: E:\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090305-044119.B1E.bin reading additional data... file saved: E:\InfinityBox\Pana01\Huawei-T161L_lock-area_20090305-044123.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 25 sec Remove/Install battery now ! |
The Following User Says Thank You to zeerik For This Useful Post: |
03-05-2009, 14:08 | #2 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Quote:
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
UNLOCK ALL MODEL Huawei T158B,Huawei T156B,Huawei T161L,Huawei,KENYANS CONTACT ME NOW | hassanjinja1 | Main Sales Section | 0 | 10-22-2009 13:45 |
Huawei T161L Successfully unlocked | zeerik | Infinity-Box | 2 | 02-03-2009 18:35 |
successfull unlock T161L | Hafiz ArslanAli | Infinity-Box | 1 | 01-20-2009 21:25 |
Huawei-T161L unlock suss | tanha | Infinity-Box | 1 | 01-06-2009 19:02 |
huawei t161L succesfully unlocked | gsmbac | Infinity-Box | 2 | 11-24-2008 16:48 |
