07-07-2008, 02:09 | #1 (permalink) |
Major Poster Join Date: Apr 2008
Member: 755881 Status: Offline Sonork: InfiEx Thanks Meter: 2 | sony ericsson k800 secomdly if i select sony ericsson from the main shell , i always get a massage missing SEClient.exe it is suppose to be in infinity box shell but its not installed. i need help infinity support . regards |
07-07-2008, 02:44 | #2 (permalink) | |
Member: 755881 Status: Offline Sonork: InfiEx Thanks Meter: 2 | Quote:
Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read eeprom Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 4 sec Remove/Install battery now ! COM37 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read eeprom Boot... Press and HOLD Power button now ! error: boot initialization step-3 failed: 85 error: boot initialization step-3 failed: 85 error: boot initialization step-3 failed: 85 error: boot initialization step-3 failed: 85 error: boot initialization step-3 failed: 85 error: boot initialization step-3 failed: 85 error: boot initialization step-3 failed: 85 error: boot initialization step-3 failed: 85 error: boot initialization step-3 failed: 85 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 6 sec Remove/Install battery now ! cable from pindfinder L12A , tried pin rx 2 , tx 3 and reverse , again rx 10 tx 11 what could it be? | |
07-08-2008, 09:56 | #4 (permalink) |
Member: 755881 Status: Offline Sonork: InfiEx Thanks Meter: 2 | k800 the k800 is made in china 11! but i think is not clone i think the problem is that the k800 is a CID 53 . in infinity software path , the ClientSE.exe is missing tried using chinese miracle but failed to read . you can see from the thread above. here is the log with different programm ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35427102***x CERT:RED FLASH CID:53 COLOR:RED Model:K800i Brand2-de MAPP CXC article: R8BF003 prgCXC1250210_GENERIC_WI MAPP CXC version: R8BF003 Language Package:EUROPE_2 CDA article: CDA102511/187 CDA version: R3A Default article: cxc1250490 Default version: R8BF003 Extended LOCKED Operator: MULTIPLE regards |
China sony ericsson k800 video converter | Shantobhai | Chinese Models & Cloned Phones | 2 | 01-11-2009 05:39 |
Sony ericsson K800 unlock code? | Muzzy | Phone Unlocking Codes & Maps | 6 | 07-30-2007 08:29 |
Sony Ericsson K800 from 3 (Hutch) Network | luigivsf | Phone Unlocking Codes & Maps | 1 | 03-26-2007 16:52 |
Sony Ericsson K800 Orange | luigivsf | Phone Unlocking Codes & Maps | 0 | 03-23-2007 19:59 |
sony ericsson k800 flashing | tanchong77 | Universalbox | 0 | 03-08-2007 10:17 |
