01-02-2009, 12:15 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Sony-Ericsson-T303 Unlock Done module v1. Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb software version: 1209-8242 software version: R2CA005 Check hardware done Read data ... reading Sony-Ericsson-T303_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20090102-161221.80E.bin Read data done Check data ... Check data done Write ... ........................... flash: 89890400040089:89890400000000 Write: simlock Write done Finished, time used: 213 sec Remove/Install battery now ! BR UMER |
The Following 2 Users Say Thank You to maplegsm For This Useful Post: |
01-02-2009, 23:15 | #2 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
01-03-2009, 08:43 | #3 (permalink) |
Freak Poster Join Date: Aug 2003 Location: lithuania ,kedainiai Age: 60
Member: 36262 Status: Offline Thanks Meter: 26 | hi COM13 [VCP2] selected module v1.30 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 46 sec Remove/Install battery now ! module v1. ???????? maplegsm |
01-03-2009, 10:22 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | t303 unlock done COM4 [VCP0] selected module v1.30 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb software version: 1209-8242 software version: R2BC003 Check hardware done Read data ... reading Sony-Ericsson-T303_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20090103-005937.80E.bin Read data done Check data ... Check data done Write ... ............................ flash: 89890400040089:89890400000000 Write: simlock Write done Finished, time used: 209 sec Remove/Install battery now ! br yasermalik |
01-03-2009, 13:26 | #5 (permalink) |
No Life Poster Join Date: Dec 2004 Location: 0x001FD00
Member: 98572 Status: Offline Thanks Meter: 36 | COM12 [VCP2] selected module v1.30 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 48 sec Remove/Install battery now ! Not working... GOod Luck... |
01-03-2009, 13:57 | #6 (permalink) | |
Freak Poster Join Date: Aug 2004 Location: Moon Age: 48
Member: 79870 Status: Offline Thanks Meter: 52 | Quote:
01-05-2009, 09:31 | #8 (permalink) |
Member: 36262 Status: Offline Thanks Meter: 26 | COM1 [Serial0] selected module v1.30 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... rom version: 0502 booting... finalizing... Boot fail error: operation failed Finished, time used: 56 sec Remove/Install battery now ! |
01-05-2009, 15:04 | #9 (permalink) |
Freak Poster Join Date: Sep 2007 Age: 37
Member: 585634 Status: Offline Thanks Meter: 45 | COM5 [VCP0] selected Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 812500 Set baud done Check hardware... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data... reading Sony-Ericsson-T303_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20090105-194409.80E.bin Read data done Check data... Check data done Writing... ............................ flash: 89890400040089:89890400000000 Write: simlock Writing done Finished, time used: 106 sec Remove/Install battery now ! |
The Following User Says Thank You to vjohn456 For This Useful Post: |
01-18-2009, 09:44 | #11 (permalink) |
Major Poster Join Date: Mar 2007 Location: Bangladesh_comilla
Member: 468952 Status: Offline Thanks Meter: 16 | COM15 [VCP1] selected module v1.30 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 46 sec Remove/Install battery now ! Not working |
01-18-2009, 15:05 | #13 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Lagos, Nigeria
Member: 152547 Status: Offline Sonork: 100.1586021 Thanks Meter: 143 | same here COM15 selected module v1.30 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb software version: 1209-8242 software version: R2CA005 Check hardware done Read data ... reading Sony-Ericsson-T303_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20090117-113300.80E.bin Read data done Check data ... Check data done Write ... ........................... flash: 89890400040089:89890400000000 Write: simlock Write done Finished, time used: 203 sec Remove/Install battery now ! |
02-11-2009, 08:20 | #15 (permalink) | |
Freak Poster Join Date: Nov 2008 Age: 43
Member: 904326 Status: Offline Thanks Meter: 62 | rong answer Quote:
module v1.30 Device: Sony-Ericsson-T303 Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 51 sec Remove/Install battery now ! | |
The Following User Says Thank You to fazi52 For This Useful Post: |
sony ericsson t303 unlock done by infinity box | zinoubinabil | Infinity-Box | 18 | 11-23-2011 13:08 |
Sony Ericsson T303 Unlock Done 100% | ms_ahmed | SETool2 | 2 | 07-20-2011 21:12 |
Sony Ericsson T303 Unlock Done 101% | ms_ahmed | SETool2 | 19 | 03-04-2010 14:51 |
Sony Ericsson T303 Unlock Done ! | .:Towhid:. | SETool2 | 2 | 03-16-2009 15:06 |
Sony-Ericsson-T303 Unlock Done | .:Towhid:. | Infinity-Box | 2 | 11-11-2008 10:56 |
