07-08-2015, 13:13 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | SONY Xperia V3+ MTK6572 1) Identify 2) Read Back (Read Factory File, Read Full Info) 3) Read NVRAM 4) Format FS Phone work, but invalid IMEI Try repair IMEI via Write NVRAM, but invalid IMEI Try repair IMEI via write security, problem with drivers. IMEI repair only with FLY drivers. But IMEI lost after Factory Reset. How repair IMEI without lost, after factory reset? Code: Start at : [08.07.2015 / 16:52:25] Operation : Check / Read Info [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 214 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D4200ECCBD49561EB DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x10000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRX9 [eMMC] : FLASH_CID : 1501004E3958524D4200ECCBD49561EB [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : mbk72_wet_lca_v30 ProdModel : V3+ Device : mbk72_wet_lca_v30 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Finish at : [08.07.2015 / 16:52:36] Start at : [08.07.2015 / 16:53:02] Operation : Read Flash [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 214 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D4200ECCBD49561EB DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x10000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRX9 [eMMC] : FLASH_CID : 1501004E3958524D4200ECCBD49561EB [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Init HSUSB Ok! Brand : alps ProdName : mbk72_wet_lca_v30 ProdModel : V3+ Device : mbk72_wet_lca_v30 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_mbk72_wet_lca_v30.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / mbk72_wet_lca_v30 / EMMC FW Size : 435 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__alps__V3+__mbk72_wet_lca_v30__4.2.2__ALPS.JB3.MP.V1\ All done! Done! Elapsed: 00:09:22 Reconnect Power/Cable! Finish at : [08.07.2015 / 17:02:25] Start at : [08.07.2015 / 17:05:37] Operation : Read NVRAM [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D4200ECCBD49561EB DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRX9 [eMMC] : FLASH_CID : 1501004E3958524D4200ECCBD49561EB [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Read Ok, Sony V3+ MT6572_eMMC.spnv saved Done! Elapsed: 00:00:46 Reconnect Power/Cable! Finish at : [08.07.2015 / 17:06:24] Start at : [08.07.2015 / 17:06:37] Operation : Format FileSystem [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D4200ECCBD49561EB DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRX9 [eMMC] : FLASH_CID : 1501004E3958524D4200ECCBD49561EB [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:44 Reconnect Power/Cable! Finish at : [08.07.2015 / 17:07:22] Last edited by Abzal; 07-08-2015 at 13:21. |
07-08-2015, 18:12 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. At now stuck with some moments with META and FLASH mode repair. Will try finish soon. For now have some idea about repair. Will add in 1.24 update. Hope - on this week. |
07-09-2015, 04:50 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | They will be supported all. For now will make "BPLGUI" database extraction from phone, to use it for MAUI after for repair. Little later will make whole calibration backup, restore, configure and imei repair as well. |
07-09-2015, 05:22 | #5 (permalink) |
Member: 19032 Status: Offline Thanks Meter: 158 | Lenovo S850T flashed to S850, not repair IMEI In "META" and in "ATE signaling Test" mode: Code: Card found: S/N C557:0128 Chinese Miracle II [MTK module] v 1.22 Operation : Repair Security [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong :( Reconnect Power/Cable! Operation : Repair Security [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong :( Reconnect Power/Cable! |
07-09-2015, 07:57 | #7 (permalink) |
Member: 19032 Status: Offline Thanks Meter: 158 | Code: Card found: S/N C557:0128 Chinese Miracle II [MTK module] v 1.23 Operation : Fix Unknown BaseBand [ v1.23 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3858564D4201D063E050715D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX8 [eMMC] : FLASH_CID : 1501004B3858564D4201D063E050715D [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #1 ... Ok Step #2 Step #2 ... Ok Reset Done! Done! Elapsed: 00:00:22 Reconnect Power/Cable! Tool DL image Fail! |
07-09-2015, 09:19 | #9 (permalink) |
Member: 19032 Status: Offline Thanks Meter: 158 | Lenovo S850 IMEI repair Not repair IMEI Code: Card found: S/N Chinese Miracle II [MTK module] v 1.23 Operation : Fix DL Errors [ v1.23 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3858564D4201D063E050715D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX8 [eMMC] : FLASH_CID : 1501004B3858564D4201D063E050715D [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Fix Unknown BaseBand [ v1.23 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3858564D4201D063E050715D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX8 [eMMC] : FLASH_CID : 1501004B3858564D4201D063E050715D [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #1 ... Ok Step #2 Step #2 ... Ok Reset Done! Done! Elapsed: 00:00:31 Reconnect Power/Cable! Operation : Repair Security [ v1.23 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong :( Reconnect Power/Cable! Operation : Fix DL Errors [ v1.23 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3858564D4201D063E050715D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX8 [eMMC] : FLASH_CID : 1501004B3858564D4201D063E050715D [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! Operation : Repair Security [ v1.23 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong :( Reconnect Power/Cable! |
07-09-2015, 09:47 | #10 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Install driver from CM2MTK installed folder and then try again. If you still face same problem then need to wait for update when more methods for repair security will be added. Br. | |
07-09-2015, 13:39 | #13 (permalink) |
Member: 19032 Status: Offline Thanks Meter: 158 | CDC Serial USB\VID_17EF&PID_74ED&REV_0216&MI_02 USB\VID_17EF&PID_74ED&MI_02 Lenovo S850 USB\VID_17EF&PID_74ED&REV_0216&MI_01 USB\VID_17EF&PID_74ED&MI_01 |
