04-13-2009, 09:58 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | sonyericsson j110i outgoing incoming calls ERROR 1) free trick for infinity user connect problem connect fone with out bettery i write eeprom from support sp unlock repair formate setting but i cant call out the fone was already unlocked error in call here is repair log COM2 [VCP2] selected module v1.32 Device: Sony-Ericsson-J110i "advanced chip detection" active Action: repair Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb software version: 039C-000 software version: KIM-5- Check hardware done Read data ... reading Sony-Ericsson-J110i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J110i_eeprom_calibration-1_20090413-015531.6AE.bin Read data done Check data ... Check data done Write ... .........data prepared Ok flash: 89886200010001:89886200000000 Write: eeprom Write done Finished, time used: 124 sec Remove/Install battery now ! plz help thanks in advance\ br yasermalik |
The Following User Says Thank You to yasermalik For This Useful Post: |
04-13-2009, 19:35 | #3 (permalink) |
Member: 488632 Status: Offline Thanks Meter: 391 | i post repair opreation bcuz i seen lot of post they all say repair option not working problem is still there i want a good and tested saloution thanks in advance br yasermalik |
The Following 2 Users Say Thank You to yasermalik For This Useful Post: |
Learn Hw 2 Record Outgoing Calls & Incoming Calls Of Ur Girl Friend On Her Own Phone | Frequency88898 | Nokia Multimedia | 78 | 11-18-2009 14:35 |
Insert sim and no outgoing/incoming calls | sarojrkl | SpiderMan | 2 | 01-21-2009 15:43 |
Learn Hw 2 Record Outgoing Calls & Incoming Calls Of Ur Girl Friend On Her Own Phone | Frequency88898 | Nokia Multimedia | 4 | 06-01-2006 13:16 |
Convert OUTGOING calls into INCOMING calls and SAVE | DianaRose | Off Topic Zone | 0 | 04-06-2004 06:48 |
BE1 not receive incomming calls. only make outgoing calls | DrMobile | Alcatel & TCL Old Models | 1 | 05-23-2002 19:19 |
