Old 05-15-2008, 17:17   #1 (permalink)
m s s spk's Avatar
Member: 705991
SONYERICSSON J120I problem
i have unlocked my mobile thourgh infinity after its show me the unauthorised error i have searched the fourm and find the solution now the problem is that after remove the unauthorised phone phone show the no network.I have download eeprom from support and try it but it's same condition i have flashed my phone too but same here is the logs
COM1 selected
Device: Sony-Ericsson-J120i
"advanced chip detection" active
Action: repair
Checking data, wait...
Boot...
Press Power button now !
loading...
Boot done
Check connection...
Check connection done
Set baud...
115200
Set baud done
Check hardware...
flash: 89886200010001:89886200000000
flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb
version sw: 039C-000
version sw: MLD-5-
Check hardware done
Read data...
reading Sony-Ericsson-J120i_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson-J120i_eeprom_calibration-1_20080515-123457.6AE.bin
Read data done
Check data...
Check data done
Writing...
.........data prepared Ok
Write: eeprom
Writing done
Finished, time used: 23 sec
Remove/Install battery now !
Loading file v.02...
J120i_Main_CXC1250845_R1C004_Aug-28-2007_MLD-5-039C-000[1].6AM.bin loaded
J120i_Flex_MLD-0-00005-0002_Cn[1].6AF.bin loaded
J120i_LP_CXC1250944_R1C004_KIM-0-100C-028_En_Cn[1].6AP.bin loaded
J120i_repair_eeprom_0B[1].6AE.bin loaded
J120i_LP_CXC1250926_R1C004_KIM-0-100C-010_En_Cz_Slovencina[1].6AP.bin loaded
J120i_repair_ffs_0A[1].6AF.bin loaded
COM1 selected
Action: flash write
"smart write" active
"format ffs" active
Write: Firmware
Write: Flex
Write: Language Pack
Write: FFS/File system
Skip: Images
Skip: Melody
Write: Eeprom
Boot...
loading...
Boot done
Check connection...
Set baud...
115200
Set baud done
Check hardware...
version sw: MLD-5-
Check hardware done
Read data...
file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson-J120i_eeprom_calibration-1_20080515-124152.6AE.bin
reading Sony-Ericsson-J120i_ffs...
file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson-J120i_ffs_20080515-124216.6AE.bin
Read data done
Check data...
Check data done
Writing...
Area: Firmware
Write: Firmware
Area: Flex
Write: Flex
Area: Language Pack
Area: FFS/File system
Area: Eeprom
Write: Eeprom
Erase: ffs
ffs format complete
Writing done
Finished, time used: 162 sec
==== log opened: [5/15/2008 12:56:27 PM] ====
Application: C:\Program Files\InfinityBox\HModule\HModule.exe
Loading data, wait...
[Infinity Box] v1.17
S/N: 01A8:010E
Wait...
Current model: Sony-Ericsson-J120i
Done
COM1 selected
Action: repair
Boot...
loading...
Boot done
Check connection...
Set baud...
115200
Set baud done
Check hardware...
version sw: MLD-5-
Check hardware done
Read data...
file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson-J120i_eeprom_calibration-1_20080515-125656.6AE.bin
Read data done
Check data...
Check data done
Writing...
Write: eeprom
Writing done
Finished, time used: 21 sec
Old 05-15-2008, 17:27   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
Did you tested phone before unlock ?
You need to make this: write repair eeprm files and make "Repair" operation.
Test phone after each eeprom file/repair.
Old 05-16-2008, 12:11   #3 (permalink)
m s s spk's Avatar
Member: 705991
Originally Posted by InfinitySupport View Post
Hello,
brfore unlock i tested the phone too and after write epprom and repair i tested but status is same
Old 05-16-2008, 12:17   #4 (permalink)
Member: 130995
What is "the same" status exactly ?
Old 05-16-2008, 13:26   #5 (permalink)
m s s spk's Avatar
Member: 705991
the same means no network sir before unlocking client told me that phone work perfect on virgin sim
Old 05-16-2008, 14:01   #6 (permalink)
Member: 130995
As I can understand phone can power-on with sim card well, no any problems like "Unauthorized".
The only problem is: phone has no network.
Is it correct ?
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 05-16-2008, 18:00   #7 (permalink)
m s s spk's Avatar
Member: 705991
Is it correct ?
now the problem is no network u are right what can we do
Old 05-16-2008, 18:05   #8 (permalink)
Member: 130995
Hello,
Try to use different flash fioles from support area. Probably need to use different eeprom files, but it's only after you will try different firmware.
Old 05-19-2008, 08:49   #9 (permalink)
m s s spk's Avatar
Member: 705991
thanks for the good advice infinity i have done it my phone is now ok
1.first i try to flash firware,flexand language pack RIA007
2.then eeprom write
3.then go to service and repair the phone thourgh repair options.
thanks to infinity to guide me
The Following User Says Thank You to m s s spk For This Useful Post:
Old 12-30-2008, 12:43   #10 (permalink)
az cells's Avatar
Member: 115516
2.then eeprom write
can u explain witch file u selected to flash plz
thanks
Old 12-30-2008, 13:37   #11 (permalink)
m s s spk's Avatar
Member: 705991
thanks
RIA007 flash firware,flex and language pack of this version and then do the procedure as above mention
Old 12-31-2008, 11:11   #12 (permalink)
az cells's Avatar
Member: 115516
thair are 3 firmaware in that folder i am confuse plz tell witch is exact firmaware flex and lp
thanks for replie
Old 12-31-2008, 13:03   #13 (permalink)
Member: 130995
Hello,
You can try to use this set of files:
J120i_Main_CXC1250845_R1A007_May-14-2007_KIM-5-032H-000
J120i_LP_CXC1250930_R1A007_KIM-0-032H-014_En_Ru_Tr_Ua
J120i_Flex_MLD-0-00001-0009
Old 01-01-2009, 12:45   #14 (permalink)
az cells's Avatar
Member: 115516
need sp unlock procedure for sony erricson j120i and j121i urgent
Old 01-01-2009, 14:10   #15 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
run hmodule
select j120i
select com port
go to service tab
press spunlock
press power button when asked
done
The Following User Says Thank You to deepakgarg For This Useful Post:
SonyEricsson j120i charging problam mahesh123 Sony Ericsson Hardware Repair Area 0 10-27-2008 15:04
SonyEricsson J120i unlock ok. rotelcam Infinity-Box 1 08-21-2008 08:51
Correct unlock SonyEricsson j120i rotelcam PolarBox 2 0 08-12-2008 19:51
SonyEricsson J120i support? Abzal Infinity-Box 2 07-12-2007 10:45
SonyEricsson flashing problem microera Griffin 5 09-18-2003 13:58
Page generated in 0.97207 seconds with 11 queries
