11-01-2008, 21:31 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | sonyericssonj110 flashing problem COM3 [VCP0] selected Device: Sony-Ericsson-J110i "advanced chip detection" active Action: flash write Write: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 89086200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: version sw: Check hardware done Read data... Read data done Check data... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user Check data done Writing... Area: Firmware flash: 060A0000060A00:068A0000000000 flash: 060A0000060A00:068A0000000000 Writing fail Finished, time used: 16 sec Remove/Install battery now ! any help |
11-01-2008, 22:56 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It looks like it's hardware fault. At first open phone and check it's hardware, it may be water inside, probably you need to replace/reball flash chip. |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
Flashing Problem UniversalBox 6110 Nokia Flashing Problem No available Boot Loader | Ravi Potdar | Universalbox | 1 | 05-29-2009 15:00 |
d780 flashing problem...after flashing ringer problem | gsm st | SWIFT Platform | 2 | 03-22-2009 22:29 |
N400 problem not power but charge is it flash problem ?? | crown | VLSI, Conexant, Skyworks and Old Models | 2 | 12-05-2003 17:23 |
N3210 flash problem. flash id:FFFFFFF | pali | Nokia Hardware & Hardware Repair | 7 | 05-26-2002 22:48 |
