01-07-2016, 19:25 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | SP Unlock I used to unlock some SPD 8810 blu phones lockewd to DIGICEL, by flashing Generic BLU firmwares for same model. tried this on 7715 by Read Generic firmware from phone and writing it to DIGICEL phone but phone is locked. is there something I can do? I have here right now both phones the locked and the unlocked and a third phone which is Locked and has the original DIGICEL firmware yet. |
01-07-2016, 21:07 | #3 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Well, I solved the unlocking by writing NVM from the unlocked phone, to the locked one. This caused the imei number to be cloned, so I tried to repair imei to the original and it didnt work in service mode, but worked in flash mode, with an error... Code: Card found: S/N : xxxxxxxx , v0129 Chinese Miracle II [SPD module] v 1.11 Operation : Repair Security [ v1.11 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 102 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Write new security data : IMEI1 : 354528073160535 Step #1 Ok Step #2 Ok Clean DIN Failed! Error code : 0x01 Error on step #3! PowerOn phone and check changes! Make Reset Settings from phone menu, if security info not changed! Write done! Elapsed: 00:01:13 Reconnect Power/Cable! |
