07-12-2018, 07:53 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | spd 6531 not detecting allways error CM2SPD1.27 need help i am facing problem....... Qmobile power 14 Code: Start at : [12-Jul-18 / 11:47:46 AM] Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SPD6531_00400000_W25Q32_SPD 6531__ Power 14-q mobile.bin 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 3 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot didn't start! Check model selection! Boot Error! Break Reconnect Power/Cable! |
07-12-2018, 08:05 | #3 (permalink) | |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Power 14 With 6531 100% Supported Quote:
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
