07-21-2017, 14:15 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | SPD 6531A REBUILD IMEI success in logs -but still imei invalid Chinese Miracle II [SPD module] v 1.27 Set mode to : SPD6531 Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0018 0000 [0] Flash VEN : GigaDevice , GD25LQ128 [0] Flash CAP : 01000000 Elapsed: 00:00:22 tried imei rebuild using tick flash mode-logs as below Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0018 0000 [0] Flash VEN : GigaDevice , GD25LQ128 [0] Flash CAP : 01000000 Process can take some time, please, wait Init ok, send data Write done! Elapsed: 00:00:49 but still imei invalid-so i tried untick flash mode and tried-but software stuck what i do as a next step? |
07-21-2017, 15:24 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Seems as you need make complete NV rebuild. Try few NVM's from similar devices. Or read dump from same models and write to faulty. Make format FS then and repair security to default values on back sticker on phone. |
