Old 10-29-2016, 08:16   #1 (permalink)
Member: 1086393
Thanks Meter: 768
SPD can't read flash file. have change all available cpu,.
Hi,
I have hello R2 working phone , I want to read flash file to write it on faulty phone, but cm2spd can't able to read, I have change all CPU but still can't read.
Card found: S/N : 8032682A , v0134
Chinese Miracle II  [SPD module] v 1.22
Operation : Read FullFlash [ v1.22 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
 ====  Wait for phone...
Phone found! [ 8 ]
Port Opened
Sync...
Initial Boot Failed!
Reconnect Power/Cable!
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
I tried with LDR MODE also
How to read? Its android 5.1 version spd chinese phone.
Need help
The Following 2 Users Say Thank You to Riteshgpt60 For This Useful Post:
Old 10-29-2016, 08:25   #2 (permalink)
.::Mosh@rof::.'s Avatar
Member: 1934602
Sonork: 100.1649323
Thanks Meter: 479
Same Problem........
Old 10-29-2016, 11:28   #3 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,977
Hello,
Try with sldr files or .pac file
Br.
Infinity Box Support Team.
Old 03-20-2017, 14:55   #4 (permalink)
Member: 2683260
Sonork: FAMILY
Same Problem........ bro how to fix this problem pls helf
Old 03-21-2017, 14:02   #5 (permalink)
Member: 1982255
Sonork: mnb_noor
Thanks Meter: 14
what is device model brother
Old 05-28-2017, 17:31   #6 (permalink)
Member: 2394561
Sonork: 383748499
Thanks Meter: 8
Same problem read file spd its very2 difficult...or read file mtk its easy...
Sent from my SM-G900H using Tapatalk
Old 05-28-2017, 18:03   #7 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,338
ALL SPD PHONES operations are based on boot keys,Without knowing Boot keys makes this difficult.if you have spd phone in hands for read flash etc... TEAM WILL HELP YOU.
Old 05-29-2017, 14:04   #8 (permalink)
Member: 1086393
Thanks Meter: 768
not only boot key, we need to know the chipset detail.
br,
Old 04-16-2018, 13:32   #9 (permalink)
Member: 2827712
Sonork: 100.1626373
Thanks Meter: 2
Card found: S/N : 53BC9A7B , v0136
Chinese Miracle II [SPD module] v 1.26
Set mode to : SP [SC983x] eMMC [Generic Android 7.x]
Set mode to : SP [SC983x] eMMC [Generic Android 6.x]
Operation : Format File System / Reset Settings [ v1.26 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 40 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
DS : Loader start failed! Wrong Model selection!
Boot failed!
3. Insert cable
Phone found! [ 8 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 8 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 8 ]
Port Opened
Sync...
Boot not done, reason : Wrong BootKeys
Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down )
3. Insert cable
Phone found! [ 8 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 8 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Old 04-16-2018, 13:47   #10 (permalink)
Member: 2827712
Sonork: 100.1626373
Thanks Meter: 2
3. Insert cable
Phone found! [ 8 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Set mode to : SP [SC773x] eMMC [Android 6.x]
3. Insert cable
Phone found! [ 8 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:27
sp {sc773x done
Old 04-16-2018, 13:57   #11 (permalink)
Member: 886246
Thanks Meter: 4
I have same problem...can not read flash but I can write easily....
Page generated in 0.39327 seconds with 7 queries
