11-30-2015, 09:40 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: kumasi-GHANA
Member: 1311694 Status: Offline Sonork: 100.1606976 Thanks Meter: 107 | Spd format error Operation : Check/Read Info [ v1.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 124 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot didn't start! Check model selection! Boot Error! Break since activated my dongle couldn,t use to format or flash before...where did i go wrong? |
11-30-2015, 14:52 | #3 (permalink) |
Member: 1311694 Status: Offline Sonork: 100.1606976 Thanks Meter: 107 | please check this one too.................................... Card found : S/N : AF60BD73 , v0129 Chinese Miracle II [MTK module] v 1.37 Operation : Format FileSystem [ v1.37 ] Operation : Format FileSystem [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 72 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 72 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:00 Reconnect Power/Cable! Operation : Format FileSystem [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 72 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
