02-17-2019, 19:20 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | Spd infinity update ?????????????????????????????????? Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 7.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitSvc Done Wait for phone... 1º Con Octopus FRP 2º Volumen menos ok Platform: __GENERAL RESET FRP METHODS Selected model: SC7731E SIGN V2 Please, reconnect battery, press and hold "Vol+" or "Vol-" button and connect USB cable. Searching for a phone. Please wait... Found phone on COM120 Connecting... Mobile Status: SPRD3 Sending preloader... Mobile Status: Spreadtrum Boot Block version 1.1 Sending mainloader... Reading info... Brand: Bitel Model: B8506 Device: B8506 Android version: 8.1.0 Display ID: Bitel_B8506_V06_20180704_1800 Searching for signatures... Resetting FRP lock.. FRP lock is successfully reseted! Backup saved as __GENERAL RESET FRP METHODS_SC7731E SIGN V2_12-12-2018_10-11-45.dump file Performed by 1.5.1.0 Software version. |
The Following 2 Users Say Thank You to m&s For This Useful Post: |
02-18-2019, 03:31 | #2 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | This reply from officials enough https://forum.gsmhosting.com/vbb/13549336-post2.html |
The Following 2 Users Say Thank You to kamal_singla For This Useful Post: |
02-18-2019, 09:04 | #3 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
If u dont no how to use SOftware then Update also useless In simple words UNTICK SVC mode then do format ur prblm will solve | |
