spd Sc7731g FRP problem log info Operation : Check/Read Info [ v1.23 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 10 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_Pike_W15.18_Debug Project : sc7731g_CP0_modem HWInfo : sc7731g_CP0_modem Compile : 03-10-2016 13:59:42 Phone Security Info : IMEI [1] : 359723070001007 IMEI [2] : 359723070001015 BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.736 V Done Reconnect Power/Cable! Only read and format in SVC Phone Model: Movitel M8409 |
choose crev android 6.0 |
Try with all 7731 boots with and without ALT LDR Mode option. New sldr files are also updated for help. Br. Infinity Box Support Team. |
Operation : Format File System / Reset Settings [ v1.23 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 61 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 37 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000007ABF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! SOLVED WITH NEW VER 1.24 thanks INFINITY TEAM Br Macie@Provider |
Hi guys i need the firmware of that phone movitel m8409 |
SU2Serial Port: COM243 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot22... Being analyzed DATA... id:Halo X-6.0-InnJoo-20160815-V1 version:6.0 model:Halo X brand:InnJoo manufacturer:InnJoo hardware:SP7731GEA_HDR_V1.0.0 >>Done. |
