Old 05-18-2017, 12:23   #1 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,338
SPD Serious Request
Hello team,
Spd773x phones with Android v5xx & v6xx Read Firmware must be improved,we encounter problems like software Not Responding. phone goes to charging mode
Hope next update will be made simple
Thank you.
Old 05-18-2017, 15:05   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,596
I have seen just 4 or 5 reports for all time.
Old 05-18-2017, 19:10   #3 (permalink)
Kwesi_Roy_GH's Avatar
Member: 2575234
Thanks Meter: 1,105
Originally Posted by Kirumira View Post
Hello team,
Thank you.
Never encountered a problem as you are complaining before. That's strange to me.
The only problem I faced was with SC7731C CPU which has been fixed a long time ago.
You need to study the tool well and know how to use it, e.g., if you need to read firmware, you
must disconnect and reconnect phone to pc 3 times as tool demands before getting successful operation
and also be able to identify your phone's boot key for connection.
Old 05-18-2017, 19:31   #4 (permalink)
JayDi's Avatar
Member: 462970
There can be drivers or cable problem, probably. I not see reason make any changes of things which are work well.
The Following 4 Users Say Thank You to JayDi For This Useful Post:
Old 05-18-2017, 21:56   #5 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,338
This is obvious indicates what i mean,All operations runs fine except Reading FLASH to the mentioned ANDROID VERSIONS
am using Win7 32bit,& Xp sp3 same problem Respected Jaydi.
@Kwesi_Roy_GH Dont try to oversmart,I understand what to do & how.
Old 05-18-2017, 23:17   #6 (permalink)
Member: 2575234
Thanks Meter: 1,105
Hello, I'm not trying to be oversmart here.
As per your comment, you can perform all operations except reading flash.
My question is, why can you perform all operation but can't read flash?
There is tricks involved in being able to read flash on this CPU.
In fact, reading flash on this CPU is the most difficult and trickiest operation ever especially when the phone's battery is non-removable.
and if you take your time and study the tool well, you will be successful.
I have experienced your complaints before and know what you are talking about.
If you need help on this, you can contact me. I will help you.
Old 05-19-2017, 07:20   #7 (permalink)
BISMILLAH MOBILES's Avatar
Member: 610502
Sonork: 100.1618428
Thanks Meter: 158
Yes..
Hello team,
Thank you.
To Dear Team,
It is not recommended and convince able that every user complaint about it.
If Mr.Jaydi see 4 to 5 reports then this should be noticed.
I also face such problems while reading or writing with these C.P.U but not write here.
May be Mr.Jaydi could have so much time and check his PM to find a message from my side.
I know this guy "Kirumira" very helpful for all Users of Infinity Box he can not be on mistake.
B/R
Sheraz...
The Following User Says Thank You to BISMILLAH MOBILES For This Useful Post:
Old 05-19-2017, 14:41   #8 (permalink)
Member: 2575234
Thanks Meter: 1,105
Now, you guys need to read this and give feedback.
The Following User Says Thank You to Kwesi_Roy_GH For This Useful Post:
Old 05-19-2017, 14:51   #9 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 833
Hello team,
Thank you.
hello you need to full power on your mobile and then power of and try firmware with pressing vol+ and vol- together
Old 05-19-2017, 15:32   #10 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,338
You`ve just made this foolscap today.
Is this a SIMPLE METHOD AS I WAS REQUESTING ???
I dont know what you loose if this is Improved !!!
The Following User Says Thank You to Kirumira For This Useful Post:
Old 05-19-2017, 17:32   #11 (permalink)
mobi_soft's Avatar
Member: 1126941
Sonork: 100.1672154
Thanks Meter: 2,471
can i chek what problem you face
via t.v
if u dnt mind
Old 05-19-2017, 19:56   #12 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,338
FINALLY I TESTED,PROBLEM WAS POPUP WINDOW MISGUIDING
online photo storage ONLY BOOT KEY WORKS
NOTE: If you HOLD BOTH VOL- & VOL+ keys,phone boots automatically to charging mode,this was working in OLD METHOD OF READ FLASH AFTER ENABLING USB DEBUGGING[ADB MODE]
TESTED ON KIMFLY M2 [VOL + IS BOOT KEY] Here we go;
READ INFO
Operation : Check/Read Info [ v1.26 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
 ====  Wait for phone...
Phone found! [ 17 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : t13_x163_bp236_64_4_dt
Model Brand : SPRD
Model Device: t13_x163_bp236_64_4
AndrVersion : 5.1
BaseBand CPU: T13_BOPAI_64_4
CompileDate : 17/11/2016 09:55:58
Project Ver : 20161117
Model Ext   : M2
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:24
Reconnect Power/Cable!
READ FULLFLASH
Operation : Read FullFlash [ v1.26 ]
3. Insert cable
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected eMMC Flash , Structure detect Ok!
[FW_READER] : Prepare Ok!
- > Wait phone connected ...
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Brand : SPRD
AndrVersion : 5.1
Model Ext   : M2
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731C_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem_w.bin
[Read Ok] : sc8830g_modem_CP2_Trunk_W15.49.3_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_480x854.bin
[Read Ok] : fblogo_480x854.bin
[Read Ok] : boot.img
[Read Ok] : system.img
[Read Ok] : oem.img
[Build Ok] : cache.img
[Read Ok] : recovery.img
[Build Ok] : userdata.img
AndroidInfo created
Firmware Size : 2124 MiB
Saved to : C:\Users\KIRUMIRA\Desktop\T13_BOPAI_64_4_t13_x163_bp236_64_4_5.1_20161117_M2\
Done!
Elapsed: 00:18:04
WRITE BACK READED FIRMWARE AFTER FLASH ERASE
Infinity SC Firmware Detected
FW Size : 2124 MiB
Load Ok!
File Info
Created by Infinity-Box (c) Chinese Miracle II (c) 2017
Device Brand   : SPRD
Device Model   : t13_x163_bp236_64_4
Device CPU     : t13_bopai_64_4
Device IntName : t13_x163_bp236_64_4_dt
Device Version : 5.1
Device Compile : 17/11/2016 09:55:58
Device Project : 20161117
Device ExtInfo : M2
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 17 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FL] : Enabled NVM update. Will program all NVM images found in FW !
PMTManager : Load 0x18 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731C_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Update NVM image : nvitem_w.bin
Update NVM Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_Trunk_W15.49.3_Release.bin
Write Data ...
Write Data Ok!
Update NVM image : nvitem_wcn.bin
Update NVM Data Ok!
Write CodeData : logo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : oem.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:04:21
CONVERT TO PAC
Operation : Convert InfinitySC to SPRD PAC [ v1.26 ]
Target : T13_BOPAI_64_4_t13_x163_bp236_64_4_5.1_20161117_M2
Step  #1 : Identify
MEMORY : eMMC
LAYOUT : eMMC NORMAL
Step  #2 : Select logic
Select Logic : SC7731
Step  #3 : Processing data
Build PAC
[ADD FILE] : nvitem_w.bin
[ADD FILE] : nvitem_wcn.bin
[ADD FILE] : prodnv.img
[ADD FILE] : u-boot-spl-16k.bin
[ADD FILE] : sc7731C_CP0_modem.bin
[ADD FILE] : DSP_DM_Gx.bin
[ADD FILE] : sc8830g_modem_CP2_Trunk_W15.49.3_Release.bin
[ADD FILE] : logo_480x854.bin
[ADD FILE] : fblogo_480x854.bin
[ADD FILE] : boot.img
[ADD FILE] : system.img
[ADD FILE] : oem.img
[ADD FILE] : cache.img
[ADD FILE] : recovery.img
[ADD FILE] : userdata.img
[ADD FILE] : u-boot.bin
Build Ok! Result : 0x0018
Sign PAC ...
Sign Ok! FW compiled!
Elapsed: 00:02:13
Saved to : T13_BOPAI_64_4_t13_x163_bp236_64_4_5.1_20161117_M2.pac
Done!
Old 05-19-2017, 20:54   #13 (permalink)
Member: 2298369
Thanks Meter: 390
READ INFO
3. Insert cable
Phone found! [ 17 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Brand : SPRD
AndrVersion : 5.1
Model Ext   : M2
Elapsed: 00:00:24
READ FULLFLASH
3. Insert cable
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Brand : SPRD
AndrVersion : 5.1
Model Ext   : M2
[Read Ok] : oem.img
AndroidInfo created
Done!
Elapsed: 00:18:04
FW Size : 2124 MiB
Load Ok!
File Info
Device Brand   : SPRD
Device ExtInfo : M2
======= Flash
3. Insert cable
Phone found! [ 17 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Flashing now
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Update NVM Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Update NVM Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Elapsed: 00:04:21
CONVERT TO PAC
Step  #1 : Identify
MEMORY : eMMC
Build PAC
Sign PAC ...
Elapsed: 00:02:13
Done!
this is true, when software again say to connect only use + or - boot key(this depend on handset), then reading start properly.
Old 05-19-2017, 21:00   #14 (permalink)
Member: 2082450
Thanks Meter: 1,431
@kirumira,
You must have known this, actually every SPD phone uses different key combination as boot key.
Some requires vol + only, some vol - only, and some (can say 60% phone) require both vol + & - simultaneously.
Hence, regardless the popup instruction, you need to connect the SPD phone, pressing the required boot key 3 time during the read flash operation when prompted by the software.
Actually the most convenient way is
First do read info, and connect phone with boot key combination...
Here you will get to know about the boot key exactly for that phone...
And during read flash, you need to use that key only while connecting the phone to PC 3 times...
P.s:
Purpose to create this post is to only make the things clear and not hurt/disrespect any person experience or anything like that
The Following User Says Thank You to chandanps18 For This Useful Post:
Old 06-05-2017, 10:36   #15 (permalink)
Member: 2592600
Thanks Meter: 16
best way i know is once phone keep turning it self on..then if the battery is removable..remove it and try with no battery..100% solution for mtk..some spd works like too... when u want to read.. better,first read info and then when device goes to flash mode .... use same mode to read
Page generated in 0.42998 seconds with 7 queries
