Old 05-19-2016, 21:44   #1 (permalink)
Member: 28559
Thanks Meter: 85
spd7731 repair imei error
i am trying to write imei on blu neo 5.0 n010l that has null imei but always get error when writing security.
what am i doing wrong?
Start at : [1/1/2006 / 3:03:51 AM]
Operation : Repair Security [ v1.18 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 172 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
Write new security data :
IMEI1 : 353805071
IMEI2 : 353805071
Error while verify security Block! Try make repair without "FlashMode" option!
Elapsed: 00:00:29
Reconnect Power/Cable!
Start at : [1/1/2006 / 3:07:27 AM]
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
Phone found! [ 130 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Open Port Failed!
Elapsed: 00:00:09
Old 05-20-2016, 07:10   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Charge battery and use good cable.
That should be enough normally.
BTW - if IMEI null and BaseBand unknown - you need reflash it with NVM update or write alive NVM.
Old 05-20-2016, 18:34   #3 (permalink)
Member: 28559
Thanks Meter: 85
ok i full charge phone and imei write successful but imei still null.
how do i fix this?
Chinese Miracle II [SPD module] v 1.18
NVM File looks Ok
Operation : Write NV [ v1.18 ]
3. Insert cable
Device boot not done
Check Drivers
Try again
NVM File looks Ok
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Write NVM Part #1 Ok!
Write NVM Part #2 Ok!
Write NVM Part #3 Ok!
Write NVM Part #4 Ok!
Clean DYNV
Elapsed: 00:00:17
2. Insert cable
Port Opened
Sync...
InitSvc Failed!
Elapsed: 00:00:04
2. Insert cable
Port Opened
Sync...
InitSvc Failed!
Elapsed: 00:00:04
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
IMEI1 : 353805071044122
IMEI2 : 353805071044130
Step #1 Ok
Step #2 Ok
Write done!
Elapsed: 00:00:21
Old 05-20-2016, 21:26   #4 (permalink)
JayDi's Avatar
Member: 462970
Seems as modem in deep stuck.
Try use "Deep Fix" option with NVM write.
If no result then need make reflashing with NVM update.
Page generated in 0.11973 seconds with 8 queries
