Old 03-23-2009, 11:50   #1 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
<<< specially to Faisal_Computer & ..::skybirds::.. for pinouts >>>
Hello Brothers, today i got china 5330 RH-37 in dead condition , pinfinder not detect pinouts & also other devices , please help me to find pinouts for this mobile here is pictures of this mobile.
Old 03-23-2009, 13:05   #2 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,254
I think It Is Better For U to Try to use the old methode that expalin in this section by useing multimeter
Good Flashing For All
Old 03-23-2009, 14:06   #3 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,370
Brother 1st off all tell us whats Cpu inside !!
2ndly , tell us what happend to that mobile ?
3rdly . tell us what is mobile condition now ? you said DEAD !! is it totelly dead ? put it on digital power supply and connect + / - and press the power button about one min. during press power button you eyes must be on Ampairs..... tell us during one min. what happening with Ampairs , and volt must be about 4.7 !!
Faisal_Computer
Old 03-23-2009, 18:43   #4 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
Faisal_Computer
thanks for reply Faisal Bahi, cpu is MTK 6225A , phone take 1 amp without power button push, after push power button phone allways take 7 amp continus , anyone see picture of test point , please search for me rx tx on the board ,thanks in advance.
Old 03-23-2009, 23:06   #5 (permalink)
Member: 148515
Thanks Meter: 14,684
hello!
have you checked infinity pinout foldeR?
Old 03-24-2009, 11:20   #6 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
hello!
yes sir , i check & not found in pinout folder.
Old 03-24-2009, 11:26   #7 (permalink)
Member: 151871
hi, what do you mean by 1 ampair !!!
it should be 0.1 not 1
am i right ?
Faisal_Computer
Old 03-24-2009, 12:07   #8 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
am i right ?
Faisal_Computer
yes you are right............
help to find rx tx with multimetter
Old 03-24-2009, 15:00   #9 (permalink)
Member: 151871
ok ......
now press the power button ( its better to sold that two contacts of power button ) now connect +/- to mobile and also connect - wire of multimetter to - connector of mobile . set multimetter to DC volts . if you have digital metter its better to you , now connect one by one all that points that you shown into picture , write down all the value that you got and post here !!
Faisal_Computer
Old 03-24-2009, 15:43   #10 (permalink)
metals's Avatar
Member: 811779
Thanks Meter: 242
Hello, Brothers,
i have done this with another device as a pinfinder with infinity box. backup full flash & eeprom of set has just upload and send to infinity . just a look on this post
New Firmware
br,
The Following User Says Thank You to metals For This Useful Post:
Old 03-24-2009, 20:27   #11 (permalink)
Member: 148515
hello!
i can offer little easyer method of pinout search:
1. set multimeter to voltage measuring.
2. check bettery voltage, it should be more than 3,7volts
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone battery attached)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
Old 03-25-2009, 10:09   #12 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,062
Next time try this pinout tested many times if not working just swap RX TX
UMER
Old 03-25-2009, 10:56   #13 (permalink)
metals's Avatar
Member: 811779
Thanks Meter: 242
[quote=maplegsm;4284214]Next time try this pinout tested many times if not working just swap RX TX
nice and good job Dear,
br,
Old 03-25-2009, 14:16   #14 (permalink)
mujahid_ali's Avatar
Member: 547967
Thanks Meter: 646
hello
mates i have this phone in hand and i try to find out RX and TX using pinfinder and i am succeeded and then i frmat the phone and it is alive here is the pinout using pinfinder
Thanxs
Old 03-26-2009, 07:07   #15 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
Originally Posted by mujahid_ali View Post
hello
Thanxs
i am failed to detect pinouts in pinfiner,
congratulation to you, but remember allways that hide your dongle id in your log window.
<<< Wich is the Best Box For SAGEM >>> Faisal_Computer ARM9 BASED M62 / M62+ 395 09-24-2018 20:11
<<< Gaoxinqi GXQ G718 CHINA MOBILE - need pinouts >>> khadim100 Infinity-Box 6 03-28-2009 06:53
what cable to upload & Download for J230i? PLZ help Me gsm_surya Sony Ericsson Media, RingTones, Games 0 07-13-2007 15:24
<<< I need list latest firmware for Nokia >>> hard UFS2 + UFS3-Tornadoflasher 3 11-25-2005 09:52
Page generated in 0.40976 seconds with 9 queries
