Old 02-01-2009, 19:41   #1 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 697
spice 410
plz tell me infinity how to unlock spice410 i reqwest tell me step by step
Old 02-01-2009, 22:37   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,402
Hello,
How to write flash (upgrade/downgrade firmware, change language):
1. connect cable from box to device
2. run "Infinity-Box Shell" software
3. select required model
4. run required software module
5. select required model (if need)
6. go to software "Settings" page and select COM port
7. go to software "Flash" page and load required files
8. press "Write" button and follow instruction given by software
How to read flash:
7. go to software "Service" page
8. press "Read flash" (or "Read full flash") button and follow instruction given by software
How to unlock (remove sp-lock, provider lock etc.):
8. press "SP-Unlock" button and follow instruction given by software
How to reset/format ffs (reset setting to default values, repair freez/restart etc.):
- at first try to make "safe format" (if this option exist)
- if "safe" option is not works try to make "complete" format (if this option exist)
8. select format mode "safe" or "complete" (if mode is available)
9. press "Reset" or "Format" button and follow instruction given by software
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 02-25-2009, 21:19   #3 (permalink)
Member: 426145
Thanks Meter: 7
Dear Sir
Pls help me unlock spice 410 i have taken newly infinity box, com port=com-1 serial0/com-4 VCPO/com-6 Vcp1, fbus/mbus, usb/com=on/off what select
thanks
sanjeev
Old 02-26-2009, 08:28   #4 (permalink)
Member: 130995
C:\Program Files\InfinityBox\Documentation\FAQ
COM4, FBUS, ON
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 02-27-2009, 12:25   #5 (permalink)
Member: 426145
Thanks Meter: 7
COM4 [VCP0] selected
module v2.66
Device: Spice-S410
Checking data, wait...
Action: read NOR flash
Boot ...
baud autodetection active
9600 autodetect
Connecting, wait...
error: boot phase#1 failed
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 267 sec
Remove/Install battery now !
Old 02-28-2009, 20:16   #6 (permalink)
Member: 130995
module v2.66
Device: Spice-S410
Boot ...
9600 autodetect
Connecting, wait...
Boot Fail
Hello,
It's a problem with cable or COM port.
Try to select other COM port and double check Rx/Tx wires.
Old 03-09-2009, 12:31   #7 (permalink)
Member: 426145
Thanks Meter: 7
Hi Sir,
i have checked cable & also com port it working fine then also finding same problem
sanjeev
Old 03-09-2009, 20:36   #8 (permalink)
Member: 358277
Thanks Meter: 476
s-410
press & hold power button until software tell to release power button. check ur connection with boards r ok.i think ur gnd track is not on exact location.make sure all three wires r properly soldered with board. any problem pm me. no box is as easier then infinity.
The Following User Says Thank You to jai2008 For This Useful Post:
Plz halp spice 410 imei rapeir how to rapeir parmodparmod Infinity-Box 15 12-08-2009 15:07
cant unloak spice s 410 madeena Infinity-Box 35 04-02-2009 13:19
cant unlock spice s-410 rathore_telecom Infinity-Box 0 07-03-2007 14:41
Spice S 410 How to unlock amit agrawal Infinity-Box 2 06-15-2007 16:43
protection card error in spice s-410 manish665 ET-BoX 3 06-14-2007 14:48
Page generated in 0.35885 seconds with 8 queries
