03-09-2011, 14:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | zonda zmtn615 sim blocked COM13 [VCP0] selected module v3.75 Device: Zonda-ZMTN615 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B7EC:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0026:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.3.75, database date: 12.02.2011): TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.T201B_C W_0_03.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.T201B_C W_0_03.BIN project-id: T201B_CW_0.03, 00000000 code offset: 00000000 ffs offset/size [01]: 00A00000/005F0000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00A00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088C4FFFF0026:2088C400000000 Backup required data Done ====> Patch required data ... ................................... lock area found ................................... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................................................. .............. error: area 1 can not apply patch Special operation Done ====> Write ... flash: 2088C4FFFF0026:2088C400000000 flash: 2088C4FFFF0026:2088C400000000 Write: lock-area-1 flash: 2088C4FFFF0026:2088C400000000 flash: 2088C4FFFF0026:2088C400000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 35 sec Remove/Install battery now ! Last edited by mrfixit; 03-09-2011 at 15:05. |
03-09-2011, 22:50 | #7 (permalink) |
Member: 60899 Status: Offline Thanks Meter: 792 | I did read unlock codes and got 12345678 see log: COM13 [VCP0] selected module v3.75 Action: read unlock codes unlock method: read codes Model: Zonda-ZMTN615 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B7EC:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: T201B_CW_0.03 Version: TINNO23C_08A_GEMINI_HW 80 byte(s) read imei: 35563303062557 connection Ok 186 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 0000 174 byte(s) read reading data... 972 byte(s) read lock[1] code: + 12345678 lock[2] code: + 56781234 lock[3] code: + 1122 lock[4] code: - 3344 lock[5] code: - 5566 lock[6] code: + 7788 lock[7] code: + 9900 if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 18 sec Remove/Install battery now ! |
The Following User Says Thank You to mrfixit For This Useful Post: |
11-05-2011, 23:24 | #9 (permalink) |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | soloution is here make full flash backup & eerpom ffs backup , for emergency full erase whole flash chip flash with Zonda-ZMTN615_TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00 .T201B_CW_0_03_2010-09-06_En_Es.B0M tick , format ffs , unlock during flash solution tested 100 % enjoy |
The Following User Says Thank You to rogerboogie For This Useful Post: |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
