spice m4580 pinout here is the pinout of m 4580 in the upper portion of sim1 u c these pinouts *** ** *** rx tx and gnd some where on the board i have successfully reset the user code today here is the log COM4 [VCP0] selected module v2.96 Action: user code unlock method: smart fast Model: Spice-M4580 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:528C:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: KACK120BFM_INA_En_HI_1.14.811 Version: KONKA23C_08B_GEMINI_HW 80 byte(s) read imei: 86326300****** connection Ok 185 byte(s) read reading data... building new data... writing data... user code set to: 0000 Finished, time used: 11 sec Remove/Install battery now ! |
Could you, please, make a photo of phone PCB and attach photo with Rx/Tx/Gnd here. Thank you ! |
i wish i could but i gave away the mobile to customer sorry i will upload it again when i get back |
spice m 4580 pin outs rx tx on the upper side of sim 1 there are five test points like *** ** these are rx and tx and ground is center between three |
You can see M4580 pinout in Infinity-Box Shell. |
We will be glad to see this pinout here too. |
4580 Pinouts 1 Attachment(s) Here is 100% final pinouts |
thank gooooooooooooooooooooooooooooooooooooooooooooooooo ooooooood jooooooooooooooooooooooooooooooooooooooooooooooooo oooooooob |
Spice M-4580 incoming call block Successfully repaired phones by Infinity-Box Quote:
Spice M4580 Pinout 1 Attachment(s) Here is an image of infinity-box pinfinder for Spice M4580 |
thnx BR .................................................. .. |
Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News - 16-10-2011 - LG, Huawei, ZTE, Orinoquia, Avio, Fly models updated 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell. It's just an example for Alcatel, if you have another model you must select your model ! http://www.infinity-box.com/download...shell_v126.jpg RJ45 connector pinout: http://www.infinity-box.com/download...pins_small.jpg Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts |
very good info bro :):):):):):) |
