Old 12-29-2009, 18:24   #1 (permalink)
adaki_vishal's Avatar
Member: 230121
Thanks Meter: 83
spice m4580 pinout
here is the pinout of m 4580 in the upper portion of sim1 u c these pinouts
rx tx
and gnd some where on the board i have successfully reset the user code today here is the log
COM4 [VCP0] selected
module v2.96
Action: user code
unlock method: smart fast
Model: Spice-M4580
Checking data, wait...
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:528C:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: KACK120BFM_INA_En_HI_1.14.811
Version: KONKA23C_08B_GEMINI_HW
80 byte(s) read
imei: 86326300******
connection Ok
185 byte(s) read
reading data...
building new data...
writing data...
user code set to: 0000
Finished, time used: 11 sec
Remove/Install battery now !
The Following 3 Users Say Thank You to adaki_vishal For This Useful Post:
Old 12-29-2009, 19:26   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 33,252
rx tx
module v2.96
Action: user code
Model: Spice-M4580
19200 autodetect
CPU: MT6223
status: FF
Date: 2000.00.00
Version: 1.0
80 byte(s) read
connection Ok
185 byte(s) read
reading data...
writing data...
Hello,
Could you, please, make a photo of phone PCB and attach photo with Rx/Tx/Gnd here.
Thank you !
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 12-30-2009, 11:46   #3 (permalink)
Member: 230121
Thanks Meter: 83
i wish i could but i gave away the mobile to customer sorry i will upload it again when i get back
The Following User Says Thank You to adaki_vishal For This Useful Post:
Old 03-04-2010, 18:18   #4 (permalink)
Member: 455935
spice m 4580 pin outs rx tx
on the upper side of sim 1 there are five test points like
** these are rx and tx and ground is center between three
Old 03-07-2010, 14:33   #5 (permalink)
Member: 1043909
Thanks Meter: 45,824
You can see M4580 pinout in Infinity-Box Shell.
Old 03-28-2010, 08:25   #6 (permalink)
{X-MAN}'s Avatar
Member: 1169043
Sonork: 100.1586033
Thanks Meter: 58
PINOUT PLZ.....
Old 03-28-2010, 18:58   #7 (permalink)
Member: 1043909
We will be glad to see this pinout here too.
Old 04-08-2010, 08:56   #8 (permalink)
sameer918's Avatar
Member: 754208
Thanks Meter: 66
4580 Pinouts
Here is 100% final pinouts
The Following 9 Users Say Thank You to sameer918 For This Useful Post:
Old 10-11-2010, 10:56   #9 (permalink)
Member: 1411161
Sonork: 75273
thank
gooooooooooooooooooooooooooooooooooooooooooooooooo ooooooood
jooooooooooooooooooooooooooooooooooooooooooooooooo oooooooob
Old 10-13-2010, 10:08   #10 (permalink)
md_amin's Avatar
Member: 1217931
Sonork: 100.1604251
Thanks Meter: 135
Spice M-4580 incoming call block Successfully repaired phones by Infinity-Box
COM5 [VCP0] selected
module v3.54
Action: reset settings ("format ffs")
Model: Spice-M4580
19200 autodetect
CPU: MT6223
chip: 0011:5FB5:000C
status: FF
Date: 2000.00.00
Version: 1.0
Version: KAAK120BFM_INA_En_Hi_1.05.725
80 byte(s) read
imei: 35868800000015
connection Ok
building list...
done
items to clear: 167
items cleared: 135 of 167
items remains: 0
Finished, time used: 2 min 51 sec
The Following User Says Thank You to md_amin For This Useful Post:
Old 04-28-2011, 17:21   #11 (permalink)
SYSTEM_GSM's Avatar
Member: 517159
Thanks Meter: 21
Spice M4580 Pinout
Here is an image of infinity-box pinfinder for Spice M4580
Old 10-15-2011, 08:10   #12 (permalink)
Maninder_111's Avatar
Member: 687144
Sonork: 1614780
Thanks Meter: 212
thnx BR .................................................. ..
Old 10-16-2011, 18:55   #13 (permalink)
Member: 1043909
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News - 16-10-2011 - LG, Huawei, ZTE, Orinoquia, Avio, Fly models updated
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell.
It's just an example for Alcatel, if you have another model you must select your model !
RJ45 connector pinout:
Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts
Old 04-14-2013, 07:36   #14 (permalink)
IMRAN_ANSARI's Avatar
Member: 1764566
Sonork: 100.1620801
Thanks Meter: 5,363
very good info bro
spice 808 pinout tarun batla Infinity-Box 1 05-24-2010 13:19
spice m4580 dual sim no incomming ukxxx Infinity-Box 3 03-22-2010 07:06
need spice S7 pinout ali_imran Infinity-Box 23 08-17-2009 06:57
i want spice d88 pinout sureshplaza Infinity-Box 1 04-16-2008 18:13
spice s920 pinouts tajinder Infinity-Box 41 10-29-2007 12:50
Page generated in 0.51854 seconds with 9 queries
