12-21-2015, 05:59 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | spice m5385 read ff failed Code: peration : Read Flash [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 25B5C7271306EF47A39222CBBE6712B6 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 6000 1700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DF , [WINBOND] W25Q64DW [0] : FLASH_DIE : 00EF 0060 0017 0000 [0] : FLASH_LEN : 0x00800000 INT_RAM : 0x0000D400 EXT_RAM : 0x00800000 SDS_INFO : 0x007F8000 , 0x00008000 Reading Flash Conent now ... Read Flash now Read Ok , 8388608 bytes read Check and collect compile info File_Info : BESTONE50_HVGA_11B_PCB01_gprs_MT6250_S00.SPICE_M5385_IND_V1_1_0_SP.bin FileVersion : SPICE_M5385_IND_V1.1.0.SP Code : 0x04, error while making FW! Make FlashRead as dump and send to support! Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
