07-02-2015, 08:18 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: I-N-D-I-A Age: 33
Member: 1119248 Status: Offline Sonork: 000000000000000000000000 Thanks Meter: 139 | Spice Mi-349 Pattern Lock Not read Try to Read but CM2 Result Not Set Pattern Read Info Operation : Check / Read Info [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 127 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 002C00BC009000660054000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0082 , [SAMSUNG] KF98G16Q4X [NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND : Detecting structure now... Please, wait. NAND : Structure detect done [30] [AP] : Initial info read Ok! Done! Elapsed: 00:00:58 Reconnect Power/Cable! Read Pattern Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 127 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 002C00BC009000660054000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0082 , [SAMSUNG] KF98G16Q4X [NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Reading data ... Please, wait Checking ... PatternLock not set Done! Elapsed: 00:01:20 At last format User data,Reset phone All done |
The Following User Says Thank You to Jaipur_Telecom For This Useful Post: |
07-02-2015, 10:18 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello, next time, please, not format it immideatily. Need to check one sample dump. Or, anyway, in v1.23 will be extend nand support. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
07-02-2015, 10:28 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Great. It will help me alot. Will try finish all need things to next or 1.23 update. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
