07-18-2015, 09:46 | #1 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | Spice Mi-362 SPD7715 Password Lock Remove Problem Read Info Code: Operation : Check/Read Info [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Send report to support! Elapsed: 00:00:32 Reconnect Power/Cable! Format Code: Operation : Format File System [ v1.02 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Unknown structure detected! Something went wrong :( If phone work normally - send report to support! Elapsed: 00:00:34 Reconnect Power/Cable! |
07-18-2015, 12:06 | #3 (permalink) |
Member: 1763238 Status: Offline Thanks Meter: 370 | when i select SC7715 eMMC Boot failed! Code: Operation : Check/Read Info [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 OO€Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
07-18-2015, 12:25 | #4 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Select firmware (.pac) or SLDR then try again. Here is success report- http://forum.gsmhosting.com/vbb/f296...l#post11169769 Br. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
07-18-2015, 12:34 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Aha, it eMMC. I will update near 100+ models to next release and try activate format for eMMC as well. |
11-14-2015, 13:37 | #8 (permalink) | |
It will not show boot error if you follow correct way- http://forum.gsmhosting.com/vbb/f296.../#post11172886 Br. | |
