08-03-2015, 07:16 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: World of technology
Member: 749754 Status: Offline Sonork: partycrasher131 Thanks Meter: 134 | Spice Mi-506 after flashing with cm2 dead Chinese Miracle II [MTK module] v 1.24 Scatter Load Ok , BaseBand : MT6572 , Project : vsun72_w_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Start at : [8/3/2015 / 11:36:20 AM] Operation : Flash [ v1.24 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D42015139D046310B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D42015139D046310B [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : vsun72_w_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000880000-0x0000000000100000 Erase : 0x0000000002580000-0x00000000A5840000 Flash Pre-Erase Done, time used : 00:00:07 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_vsun72_w_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:42 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:04 Update RomInfo done Done! Elapsed: 00:04:07 Reconnect Power/Cable! |
08-03-2015, 08:24 | #3 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
there is not any kind of problem in 6572 cpu - may be u flash ur phone with wrong ver | |
08-03-2015, 14:28 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | "Repartition" mandatory select, when you change FW version. Will try add detect, need it or not automatically. |
03-13-2016, 11:34 | #11 (permalink) |
Insane Poster Join Date: Aug 2010
Member: 1383145 Status: Offline Thanks Meter: 8 | Spice-Mi-506-IND-Ver15.0-New …::::Flash Reed::::… PLEASE READ AFTER FLASH YOUR PHONE 1. DO NOT FLASH OFFICIAL FIRMWARE IN ANY BOX (SOME USERS DEAD MANY SET WHEN SET SHOW IN LOGO). 2.PLEASE ONLY USER DATA ,RECOVERY FIRST FLASH (MANY SET ARE DIFFERENT VERSION SO, WHEN SET FULL FLASH SET IS WHITE SCREEN OR DEAD ). 3.IF SP NEW FLASH TOOL ARE SHOW ERROR PLEASE USE OLD VERSION I AM DONE IN MANY TIME. How To Flash MTK Android (Sp flash tool ) tutorial |
03-13-2016, 13:21 | #14 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Post flashing log. And btw no need to flash for password, just safe reset user lock or format if data not needed. What is your same problem, post details. Br. Infinity Box Support Team. | |
