Old 10-12-2014, 16:30   #1 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,025
Spice mi-508
Spice mi-508
pin lock hard reset still done same
CM2MTK LOGS
HOLDING VOL+
Operation : Check / Read Info [ v1.03 ]
Wait for phone...
Phone found! [ 28 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6571_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 7001004D4D4330344758F8792A4171F7
DA Stat : v4.2 on BBID : 0x8B
DA Sent. Configure setting now ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C
[NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000
[NAND] : FLASH_LEN : 0x00000000
INT RAM    : 0x00000000
EXT RAM    : 0x00000000
BOOT TYPE  : DONE
SOC VERIFY : 00
Boot Ok!
Info read not done :( Erased phone or unsupported FlashIc?
Done!
Elapsed: 00:00:19
Reconnect Power/Cable!
The Following User Says Thank You to VIJAY2U2 For This Useful Post:
Old 10-12-2014, 17:24   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,181
Hello , please, contact with me in PM after 10 hours in any time, we will try make something.
Old 10-12-2014, 20:03   #3 (permalink)
Member: 1043909
Thanks Meter: 51,302
@amancommunicati
Its final warning.
If you do not stop your stupid activity I will contact to forum admins with ban request !
Old 05-03-2015, 12:42   #4 (permalink)
Member: 1988632
please any solution spice mi 508 privacy lock not done after hard reset and flash with sp tool please short out this problem
Old 05-03-2015, 13:07   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,597
Infinity can fix that without any problem, but seems as you not have it. Seek solution in other place.
Old 05-25-2015, 07:56   #6 (permalink)
Member: 1390202
hold vol up and power
after andriod logo
press power
select wipe data option with vol down key
press vol up key for ok
Page generated in 0.22680 seconds with 7 queries
