03-23-2008, 05:50 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab Age: 44
Member: 476739 Status: Offline Thanks Meter: 507 | Cect Lv-918 Dead After Ffs I HAVE CECT LV-918 MODEL PHONE FFS COMPLETE SAVE EEPROM OPERATION IS DONE BUT AFTER FFS PNONE IS DEAD THEN I M WRITE EEPROM Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:C703:0006 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 2088C4BFFFBFFF:2088C400000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 80323-103132.B0E.bin flash: 2088C4BFFFBFFF:2088C400000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Area: Eeprom/ffs flash: 2088C4BFFFBFFF:2088C400000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done Finished, time used: 406 sec Remove/Install battery now ! PHONE NOT POWER ON PLEASE HELP ME INFINTY TEAM |
03-23-2008, 09:00 | #3 (permalink) |
Member: 476739 Status: Offline Thanks Meter: 507 | PLESE READ MY FULL POST IM ALLREADY WRITE EEPROM NO RESULT AFTER BAD RESULT IM FLASH FORMWARE CM_Cect-LV918_Bluetooth-2.0_MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00.M608_V_1 _07_P1HXM25BC30_CN__16m_Ru_Fr_En_Th_Vn_Ar_w_eeprom .B0M BUT NOT RESULT BAD RESULT PHONE IS DEAD |
03-23-2008, 14:07 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! what was initial problem with phone? did you try safe format before complete? what result? after complete format did you try to power On phone with long press to power button (like 30-40sec) are you sure your battery voltage is ok? measure it, it must be greater than 3,7volts |
03-26-2008, 05:59 | #5 (permalink) | |
Member: 476739 Status: Offline Thanks Meter: 507 | Quote:
cect v-180 dead after formatting | manish patel122 | Chinese Models & Cloned Phones | 7 | 03-15-2010 15:17 |
Succesfull with Bluetooth 2.0 CECT LV-918 "Bad Software" problem | sagtel | Infinity-Box | 187 | 09-14-2009 21:47 |
Siroya please hellpme f275l dead after ffs format | soulcelulares | UST Pro II | 2 | 07-16-2009 16:31 |
chaina mobile dead after ffs complete format | sajidashraf | Infinity-Box | 3 | 06-06-2009 08:48 |
fly 2040 dead after ffs | singhdeep | Infinity-Box | 10 | 12-23-2008 17:25 |
