Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2005 Location: Chandigarh ,UT ,India Age: 37
Member: 107258 Status: Offline Thanks: 2
| Spice S-404N Flash And Battery Connection How To Hello Team , As Always By Best Team ,I Need To Ask question Seldom The Userbase and everything here is so great .This time i have a diff question Q :I got a Spice S-404N And I Have No Cable To the Same .So I Plan To Make a Cable For The Same And Solder It For Rx ,Tx And GND .But I Would Like To Know That How Will I Install The Battery As It Needs Power When Unlocking ,If i Have Autofinder Box Can i Unlock and Give Power At Same Time . ![]() Thanks In Advance Amarbir Singh Dhillon Chandigarh . |
| | #2 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 9,049
| Hello, You need to solder wires to phone test points and install battery after soldering wires. Yes, you can use Infinity-Box PinFinder as a cable (and take power from PinFinder instead of battery) |
| | #3 (permalink) | |
| Quote:
On the Infinity Box I Have the Left And Right RJ45 Socket ,I always USe the Left side One ."Are They different " .And If I Connect the Autopinfinder To The Left side Of The Main Dongle Then How Do i Take Power As I Have To Connect Cable To the Autopin Finder Box RJ45 Socket .Please Enlighten Me .the Method Of Putting The Battery Is Understood though ,I Just Completed the Job With That But i Wanna Know If I do not put the battery then how do i do it | |
| | #4 (permalink) |
| Hello, I understand nothing. Please, explain why you connect PinFinder to Infinity-Box if you have used RJ45 connector of PinFinder. Please, explain what you have tried to do. Also, please, read this: http://www./showthread.php?t=342807 |
| | #5 (permalink) |
| First , I Read The Link ,Thanks For The Same .My Question For You Was 1 :My Problem is That If I Have No Cable For a Phone And Make One And Connect the Rx ,Tx And GND To The Phone "If The Connections Are Under The Battery" And I Am Not Able To Connect or Push in the Battery in The Mobile Phone Cos The Cables Will Not Allow "Like in Spice S-404N" .Then How Do i Give Power To The Mobile .Once Solution Is To Make A RJ45 Cable with Pin 1 and 8 Connected To The Battery and Pin 2 And 3 and 7 Connect To Rx/Tx And GND . Ps :I Have Infinity Box autopin Finder Box Also .In Your Fist Post To Me You Said i Could Use Autopin Finder |
| | #7 (permalink) |
| Sir , Exactly You Are Repeating What i Was Saying .I Will Make That Cable and Click And Photo For Users .Can the Main Infinity Box Give +5 Volt Power To Pin 1 Or We Need Use autofinder Box Also .Secondly The Output Would Be Dangerous For Phone ,they Need 3.7 Volt |
| | #9 (permalink) |
| Dear Friend, Could you, please,ask your questions in more easy-to-understand way ? To be honest I can't understand your questions well. Anyway, here is very clear and very detailed explanation: 1. take your Infinity-Box (only Infinity-Box, nothing else) 2. connect RJ45 cable into left Infinity-Box RJ45 3. use RJ45 pin-1 instead of +battery 4. use pin-8 (or pin-7) instead of -battery 5. use pin-2 and pin-3 as Rx/Tx. Some additinal information to avoid future questions: 1. read this: need s404 spice cable and you will see pictures how to build cable for S404 (this link can be found in FAQ, but to make everything so easy as possible I don't suggest you to read FAQ as it's just a waste of time but I post direct link here) 2. if you have phone with battery you can use battery and connect from box only Rx/Tx/Gnd wires (accoring to previous link). In most cases it's the easiest way to amke something instead of try to connect 4 wires instead of 3, it's safest way and also pictures attached by above link so I hope that explanation (3 wires + battery) is quite clear and easy to understand). Please, confirm, is it enough clear explanation ? Last edited by InfinitySupport; 03-26-2008 at 09:45. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| TMA Cable and CYCLONE BOX HOW to Connect explained | 10xs4asking | Cyclonebox | 22 | 01-10-2010 15:52 |
| k 550! flash ic is pasted how to connect testpoint | k babu | DreamBox | 1 | 11-26-2009 16:48 |
| A835 Reset as Battery Insert . How to Factory SET ? Urgent Help Required ... | Aamir_Zia | P2k Series | 5 | 08-07-2005 14:34 |
| Lg 7030 And Lg W7000. How To Flash These Models | MindPower | LG | 0 | 07-08-2004 21:06 |
