spice s 404n is not supported by infinty hi, i hv s 404n for unlocking but not supported with infinty box. pls add spice n404. thx wbr [email protected] |
check the box again infinity support spice s 404 u downlode new updates |
not supported with infinty box. pls add spice n404. |
I tested Unlocking so many Spice S404 with infinity.. Download the latest updates and check brother.. DOuble check ..Double CHeck. Rgards. Deepssss. |
spice s404 it support s404 but not s404n |
hello! please read out full lfash from S404n and send to us. we will make update |
How do I unlock spice s545 is it supported by infinity, the pin outs are same like s400,405. |
i have so many handset unlock s404n without any problem.with infinity-box. br.. parveen |
REGARDS |
tryed to unlock with m module v 1.62 but for 2,3 scound its showing manu & then showing network not supported need help please regards |
You must explain what you tried and what is the problem. |
TRYED TO WRITE REPAIR EPROM ,UNLOCK FFS BUT STEEL SAME COM1 [Serial0] selected Device: Spice S404 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Check space... reading [eeprom]... file saved: backup_eeprom_20071010-001029.B0E.bin flash: EC22A000000000:18E59F00000000 Check space Done Manipulation... detection procedure, wait... detection procedure completed Manipulation Done Finalization... ................ ................ ................ Finalization Done Write... flash: EC22A000000000:18E59F00000000 Write: eeprom Write Done Finished, time used: 122 sec Remove/Install battery now ! REGARDS |
hello! what is a phone state now? does it work ok without card? does it call 112 without card? |
