Old 07-30-2009, 15:51   #1 (permalink)
Member: 358277
Thanks Meter: 476
spice s-525 unlock problem
infinity team i m having error in unlocking s-525 . checked all thread. done all procedure . any correct link & procedure plz share. problem is when we unlock only first time inserted sim is working. when change sim set is again locked. any complete solution is there.
The Following User Says Thank You to jai2008 For This Useful Post:
Old 07-31-2009, 09:39   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
If you have problems with S525 unlock:
1. make full flash backup for emergency case
2. flash phone with firmware: Spice-S525_IACN05_07B_PCB01_GSM_MT6205B_DN.2_00_En_Hindi
3. try to make unlock
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 08-03-2009, 09:02   #3 (permalink)
Member: 358277
Thanks Meter: 476
unlock problem
hi sir. i flash it with ur desired fls file but now set is showing enter sim m pin.set is not showing code of unlock when i use read code option. any other solution. its an emergency now.
Old 08-03-2009, 09:08   #4 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
tryunlock again on standard fast method..
The Following User Says Thank You to himanshu taldar For This Useful Post:
Old 08-03-2009, 09:45   #5 (permalink)
Member: 520918
Thanks Meter: 8
Red face Spice S525 wrong sim
Very true.....................wrong sim problem with spice s-525.tried all funtions available in infinity latest setup and updated.sp unlocked....................flashed............... ..reset settings...................wrote new eprom,but everything in vain.after all process only sim working is the first one used after the above process. Rest all wrong sim. Infinity team please help.
Regards
pradeep
The Following User Says Thank You to pradeepkool For This Useful Post:
Old 08-03-2009, 10:54   #6 (permalink)
Member: 130995
Hello,
Post here unlock logs and all your steps exactly.
Are you sure that you have flashed phone with firmware that I talk about ?
http://forum.gsmhosting.com/vbb/show...72&postcount=2
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 08-03-2009, 19:29   #7 (permalink)
Member: 358277
Thanks Meter: 476
spice s-525 unlocked
dear infinity team. thanx for ur support. i have finally unlocked my spice s-525 with given procedure. flash ur handset with desired fls file. Spice-S525_IACN05_07B_PCB01_GSM_MT6205B_DN.2_00_En_Hindi then simply unlock ur handset by standard fast method. u can use any sim in it.
The Following 2 Users Say Thank You to jai2008 For This Useful Post:
Old 08-31-2009, 11:58   #8 (permalink)
experttelecom's Avatar
Member: 914898
Sonork: 100.1597109
Thanks Meter: 117
unlock complete done with this method
The Following User Says Thank You to experttelecom For This Useful Post:
spice s 525 unlocking sgs_41 Infinity-Box 2 04-18-2009 14:05
spice s-525 unlocked jai2008 Infinity-Box 0 03-26-2009 19:04
spice s-525 unlock 100% succesfull all sim working ..::ohm::.. Infinity-Box 1 02-18-2009 09:40
Nec 525 unlock problem Moosani Redbox 14 06-03-2005 17:55
NEC 525 unlock problem joealexv Redbox 7 10-07-2004 05:31
Page generated in 0.22109 seconds with 9 queries
