05-19-2008, 18:57 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab Age: 42
Member: 478791 Status: Offline Thanks Meter: 52 | spice s 530 is still on n p code tried flash and repair eprom and unlock plz help COM4 [VCP0] selected Action: unlock unlock method: smart fast Model: Spice S530 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 29 sec Remove/Install battery now ! COM4 [VCP0] selected Device: Spice S530 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled enhanced security fix enabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 01227E22022201:18E59F00000000 Backup required data Done Patch required data... .............. lock area found Patch required data Done Special operation... detecting additional parameters... ................................ error: additional parameters detection failed Special operation Done Write... flash: 01227E22022201:18E59F00000000 flash: 01227E22022201:18E59F00000000 Write: lock-area-1 Write Done Finalization... Finalization Done Finished, time used: 31 sec Remove/Install battery now ! Loading file v.02... Spice-S530_05B0604V11[1].G623A301.F2_00S1S_G53_PLUS_HW_2006-06-13_En_Cn.B0M.bin loaded detecting languages... Languages: En Hi COM4 [VCP0] selected Device: Spice S530 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs enhanced security fix enabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Area: Firmware flash: 01227E22022201:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done Finished, time used: 130 sec Remove/Install battery now ! Loading file v.02... Spice-S530_repair_eeprom_04.B0E.bin loaded COM4 [VCP0] selected Device: Spice S530 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs enhanced security fix enabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Area: Eeprom/ffs flash: 01227E22022201:18E59F00000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done Finished, time used: 33 sec Remove/Install battery now ! Loading file v.02... Spice-S530_05B0604V11[1].G623A301.F2_00S1S_G53_PLUS_HW_2006-08-31_En_Hindi_ver2.B0M.bin loaded detecting languages... Languages: En Hi COM4 [VCP0] selected Device: Spice S530 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs enhanced security fix enabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Area: Firmware flash: 01227E22022201:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done Finished, time used: 130 sec Remove/Install battery now ! COM4 [VCP0] selected Device: Spice S530 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard fast enhanced security fix enabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 01227E22022201:18E59F00000000 Backup required data Done Patch required data... .............. lock area found Patch required data Done Special operation... detecting additional parameters... ................................ error: additional parameters detection failed Special operation Done Write... flash: 01227E22022201:18E59F00000000 flash: 01227E22022201:18E59F00000000 Write: lock-area-1 Write Done Finalization... Finalization Done Finished, time used: 31 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM4 [VCP0] selected Action: reset settings Model: Spice S530 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 16 sec Remove/Install battery now ! ==== log opened: [5/19/2008 6:27:30 PM] ==== Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.20 S/N: 37E9:010E Wait... Device: Spice S404 Done Device: Spice S404 Loading file v.02... Spice-S404_GW15_PCB01_GSM_MT6205B_DN[1].1_00_2005-12-14_En_Cn.B0M.bin loaded identification#1 protocol ver: 02 ver. sw1: GW15_PCB01_GSM_MT6205B_DN.1_00.BIN ver. sw2: 1.00, 00000000 detecting languages... Languages: En Hi Loading file v.02... Spice-S404_GW15_PCB01_GSM_MT6205B_DN[1].1_08_2006-11-18_En_Hindi.B0M.bin loaded Loading file v.02... Spice-S404_IACJ_GW15_HW_2007-01-11_05B_GW15_En_Hindi[1].B0M.bin loaded COM4 [VCP0] selected Device: Spice S404 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active "format ffs" active write: Firmware write: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom_20080519-183053.B0E.bin Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Area: Firmware flash: EC22A000000000:18E59F00000000 Write: Firmware Area: Customization/Language Pack flash: EC22A000000000:18E59F00000000 Write: Customization/Language Pack Area: Eeprom/ffs flash: EC22A000000000:18E59F00000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... formatting... flash: EC22A000000000:18E59F00000000 Finalization Done Finished, time used: 337 sec Remove/Install battery now ! Last edited by unlock_solution; 05-19-2008 at 18:59. Reason: mistake |
05-20-2008, 00:23 | #3 (permalink) |
Member: 478791 Status: Offline Thanks Meter: 52 | Spice-S404_GW15_PCB01_GSM_MT6205B_DN[1].1_08_2006-11-18_En_Hindi.B0M.bin loaded Spice-S530_05B0604V11[1].G623A301.F2_00S1S_G53_PLUS_HW_2006-08-31_En_Hindi_ver2.B0M hi sir already done this see in log i flashed it with these files still same |
05-20-2008, 00:36 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Please, give me answers for all the next questions: 1. What is imei now ? 2. Did you tried to repair imei to it's original value ? 3. What was the reason to use S404 files for S530 phone ? 4. What was initial phone state ? |
05-20-2008, 02:47 | #5 (permalink) |
Member: 478791 Status: Offline Thanks Meter: 52 | hi sir now phone imei is changed origional imei is 357048002458600 and now imei is 357048002422564 and sorry for wrong log copied i flash a s404 in that process that log also copied with that log sorry and now phone is asking for network provider code ..........i canot try to repair imei i repair imei and then post results wbr varun always thankfull for great support |
05-20-2008, 18:54 | #7 (permalink) |
Member: 478791 Status: Offline Thanks Meter: 52 | hi sir now phone imei is in original state and after that phone is in same condition again i try with standard method but still same and then i flash it and then try with standard method but still same here is log ............plz tell me what i do ==== log opened: [5/20/2008 10:15:26 PM] ==== Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.20 S/N: 37E9:010E Wait... Device: Spice S530 Done COM4 [VCP0] selected Device: Spice S530 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information enhanced security fix enabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 23 sec Remove/Install battery now ! Loading file v.02... Spice-S530_05B0604V11[1].G623A301.F2_00S1S_G53_PLUS_HW_2006-08-31_En_Hindi_ver2.B0M.bin loaded detecting languages... Languages: En Hi COM4 [VCP0] selected Device: Spice S530 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs enhanced security fix enabled Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Area: Firmware flash: 01227E22022201:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done Finished, time used: 31 sec Remove/Install battery now ! COM4 [VCP0] selected Device: Spice S530 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard enhanced security fix enabled Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom_20080520-222112.B0E.bin flash: 01227E22022201:18E59F00000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... detecting additional parameters... ................................ error: additional parameters detection failed Special operation Done Write... flash: 01227E22022201:18E59F00000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 65 sec Remove/Install battery now ! Last edited by unlock_solution; 05-20-2008 at 19:00. Reason: mistake |
05-21-2008, 12:25 | #12 (permalink) |
Member: 478791 Status: Offline Thanks Meter: 52 | ry code 000000 for me work when i got this type situation .. hope for you also Good Luck Br working brother with 000000 thanx ................... wbr varun |
Repair Eprom and fullflash E251 | Rpncboy | Z3X-Team Products | 0 | 12-01-2009 22:39 |
spice s5 unable to unlock!!! Plz help | ezysuresh | Infinity-Box | 3 | 12-01-2008 16:50 |
K310i Dead after trying to unlock . plz help | A-H-T | Cruiser Suite | 9 | 04-14-2008 14:40 |
E606 is still on nec | khurram786 | NEC | 0 | 08-22-2007 13:05 |
Z300 subset lock is still on after unlock, why? | tekit.dk | Samsung (USB-Smart) | 0 | 04-27-2006 09:16 |
