Old 03-12-2010, 13:49   #1 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,975
Arrow Spice S-820 dead after flash-
Hi,
I received S-820 in blinking condition, I flashed it with "S820_A7336_26M_06B_PCB01_GPRS_MT6226M_S01.7S7336IN 00-001-R1L_En_Hi.B0M.bin" firmware and set got dead. Here is the log-
COM3 [VCP0] selected
module v3.25
Device: Spice-S820
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
Spice-S820_A7336_26M_06B_PCB01_GPRS_MT6226M_S01.7S7336IN 00-001-R1L_En_Hi.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6219:8B02:8B01]...
CPU: MT6219
detected CPU: MT6226MA
chip: 0031:47C1:C666
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98004900000002:2CEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
otp offset: 00FF0000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.19F8A 33F.[A7336_26M_06B_PCB01_GPRS_MT6226M_S01.7S7336IN00-001-R1N.BIN_19624A65].rpl
rom info detection finished
New firmware detected (v.3.25, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
device-id: 19F8A33F
rom info ver: 05
sw version: A7336_26M_06B_PCB01_GPRS_MT6226M_S01.7S7336IN00-001-R1N.BIN
project-id: 7S7336IN00-001-R1N, 654A6219
code offset: 00000000
TCL-ID is absent
ffs/eeprom address can not be detected, value from database assigned: 00000000/00000000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
ffs addres range is empty
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 calculation...
startup code area #1 fixed
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Spice-S820_A7336_26M_06B_PCB01_GPRS_MT6226M_S01.7S7336IN 00-001-R1N__system_log_19F8A33F_19624A65_20100312-163925.B0X.bin
Area: Firmware
Write: Firmware
Write Done
====> Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Spice-S820_A7336_26M_06B_PCB01_GPRS_MT6226M_S01.7S7336IN 00-001-R1N__system_log_19F8A33F_19624A65_20100312-170621.B0X.bin
Finished, time used: 27 min 52 sec
Remove/Install battery now !
If anyone have this firmware -"A7336_26M_06B_PCB01_GPRS_MT6226M_S01.7S7336IN 00-001-R1N.BIN" plz upload it.
Meanwhile Iam trying to flash it with the given other firmwares on support.
Thnx.
Old 03-12-2010, 15:53   #2 (permalink)
Member: 1043909
Thanks Meter: 51,299
Hi,
Try to flash phone with IMobile-520 flash file.
What is the results ?
Old 03-12-2010, 16:18   #3 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,975
Already flashed with all IMobile-520 flash files, set only shows "I-Mobile" and then gets switch off. I think it needs the original flash file which was in the phone- "A7336_26M_06B_PCB01_GPRS_MT6226M_S01.7S7336IN 00-001-R1N.BIN".
Wr.
Old 07-22-2010, 18:50   #4 (permalink)
Member: 1264285
Thanks Meter: 3
Unhappy solanki telecom
bhai sab mere spice 820 ka kya hua...
Old 07-22-2010, 19:25   #5 (permalink)
Member: 1043909
I did not understand your question well. Please, explain your idea well.
spice s404 dead after flash indian mobiles Infinity-Box 8 04-01-2011 13:39
spice s-820 dead anurag_arora Infinity-Box 1 12-05-2009 22:13
spice s 404 dead after flash unlock_solution Infinity-Box 15 01-25-2009 19:45
Ke 820 dead after flash KingOfGsm VygisToolbox 3 10-11-2008 17:49
E 250 & x 820 dead after read flash bna UST Pro II 2 07-07-2008 22:29
Page generated in 0.33397 seconds with 8 queries
