03-18-2009, 07:05 | #1 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 200548 Status: Offline Thanks Meter: 104 | spice s525 sucessfully unlocked module v2.58 Device: Spice-S525 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25032501:18E59F00000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: IACN05_07B_PCB01_GSM_MT6205B_DN.2_02_P.BIN ver. sw 2: 2.02_P, 00000000 ffs offset/size: 00300000/000E0000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[IACN05_07B_PCB01_GSM_MT6205B_DN.2_02_P.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[IACN05_07B_PCB01_GSM_MT6205B_DN.2_02_P.BIN]_20090318-113427.B0E.bin flash: EC257E25032501:18E59F00000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting additional parameters... ......... flash: EC257E25032501:18E59F00000000 flash: EC257E25032501:18E59F00000000 Write: area 0/1 ....... additional parameters detected Ok detecting additional parameters... ................ error: additional parameters detection failed detecting additional parameters... ...... flash: EC257E25032501:18E59F00000000 flash: EC257E25032501:18E59F00000000 Write: area 2/1 .......... additional parameters detected Ok Special operation Done Write ... flash: EC257E25032501:18E59F00000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 241 sec Remove/Install battery now ! thanx infinity team |
The Following User Says Thank You to bittubansal For This Useful Post: |
03-18-2009, 23:40 | #3 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
unlock spice s525 with et box? | SAHIL MIDHA | ET-BoX | 1 | 10-26-2009 05:28 |
.:: Spice S525 Unlocked Successfully ::. | [Shadab_M] | Infinity-Box | 5 | 05-21-2009 07:32 |
problem in unlocking spice s525. | digitized | Infinity-Box | 4 | 05-07-2009 12:55 |
spice s525 | sumit khurana | ET-BoX | 1 | 11-26-2008 08:10 |
Spice S410 sucessfully unlocked | sallupat | Infinity-Box | 1 | 01-28-2008 03:56 |
