05-12-2009, 08:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | .:: Spice S525 Unlocked Successfully ::. Code: COM15 [VCP1] selected module v2.58 Device: Spice-S525 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25032501:18E59F00000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: IACN05_07B_PCB01_GSM_MT6205B_DN.1_03_P.BIN ver. sw 2: 1.03_P, 00000000 ffs offset/size: 00300000/000E0000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25032501:18E59F00000000 Backup required data Done Patch required data ... .......... lock area found .......... lock area found Patch required data Done Special operation ... detecting additional parameters... ......... flash: EC257E25032501:18E59F00000000 flash: EC257E25032501:18E59F00000000 Write: area 0/1 ....... additional parameters detected Ok detecting additional parameters... ................ error: additional parameters detection failed detecting additional parameters... ...... flash: EC257E25032501:18E59F00000000 flash: EC257E25032501:18E59F00000000 Write: area 2/1 .......... additional parameters detected Ok Special operation Done Write ... flash: EC257E25032501:18E59F00000000 flash: EC257E25032501:18E59F00000000 Write: lock-area-1 flash: EC257E25032501:18E59F00000000 flash: EC257E25032501:18E59F00000000 Write: lock-area-4 Write Done Finalization ... Finalization Done Finished, time used: 43 sec Remove/Install battery now ! Thank you Infinity Team Br, Shadab Ahmad |
05-12-2009, 21:23 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Did you tried to use another unlock methods ? If you have problems with S525 unlock: 1. make full flash backup for emergency case 2. flash phone with firmware: Spice-S525_IACN05_07B_PCB01_GSM_MT6205B_DN.2_00_En_Hindi 3. try to make unlock |
05-20-2009, 13:44 | #4 (permalink) | |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
Problem solved! Regards, Shadab Ahmad | |
05-21-2009, 04:03 | #5 (permalink) |
No Life Poster Join Date: May 2006 Location: lucknow
Member: 275643 Status: Offline Thanks Meter: 360 | i' also unlock spice s525 unlock, really ultimate box, fist time when i unlock spice s525 it show sim card, but after one day custmor tell me on phone that it show wrong sim card, yesterday i again flash phone and after that sp unlock, now phone is doing well, but i'm not sure that wrong sim card problem not come again ? |
05-21-2009, 07:32 | #6 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
http://forum.gsmhosting.com/vbb/show...81&postcount=3 | |
The Following User Says Thank You to deepakgarg For This Useful Post: |
.::t715 cid53 unlock successfully ::. | .::ZUBAIR::. | SETool2 | 14 | 03-20-2010 21:16 |
::..:: N95 8G Unlocked Successfully with UB in FEW SECONDS ::..:: | mujahid_ali | Universalbox | 1 | 04-07-2009 06:47 |
Spice New model S525 unlock successfully with module 2.64 | kmaxmax | Infinity-Box | 2 | 02-28-2009 20:44 |
.:: VODA 716 unlocked done ::. :: THX FOR REPORT :: | keaelite | PolarBox 3 | 0 | 12-29-2008 05:30 |
