12-25-2009, 15:51 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Spice s585 phone code reset by selecting j-max jm 5700:) Code: COM3 [VCP0] selected module v1.72 Device: J-Max-JM5700 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! e-gold: A0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:0102 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\J-Max-JM5700_eeprom-static_20091225-201823.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\J-Max-JM5700_eeprom-security_20091225-201825.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\J-Max-JM5700_eeprom-complete_20091225-201841.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 57 sec Remove/Install battery now ! WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
12-26-2009, 08:11 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,425 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. Br Faisal_Computer |
12-26-2009, 13:42 | #3 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | Code: Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. Br Faisal_Computer |
12-26-2009, 13:49 | #4 (permalink) | |
Member: 151871 Status: Offline Thanks Meter: 71,425 | Quote:
Br Faisal_Computer | |
12-28-2009, 10:07 | #5 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
Mr. Faisal_Computer helps us in this forum. | |
i8510 phone code reset FOR FREE. by the share4gsm.com | ZetMen | Samsung Flashers, Software, Firmware. | 22 | 03-04-2018 16:23 |
::.::w205 Phone lock code reset by setool without credit::.:: | roney_nexus | SETool2 | 21 | 06-05-2013 09:37 |
w395 phonelock code reset by select model w302 | [email protected] | Cruiser Suite | 2 | 09-23-2009 14:14 |
pls help for gx10i phone code reset | bozan | Sharp | 9 | 11-23-2003 11:11 |
GX10i Phone code reset | dominik | Sharp | 12 | 11-11-2003 15:15 |
