08-08-2008, 13:30 | #1 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Spice S600n Show this error........ Check Out... It is in dead condition. I first try to Format FFS but not work. During Format FFS phone show this error. Code: COM11 [VCP0] selected Device: Spice S600N Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6217:8A00]... CPU: MT6217 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................................................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 98004900000002:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 98004900000002:FFFFFF00000000 error: no any expected answer error: flash erase error: 00900000 error: no any expected answer error: erase #E2 Finalization Fail Finished, time used: 55 sec Remove/Install battery now ! Code: COM11 [VCP0] selected Device: Spice S600N Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6217:8A00]... CPU: MT6217 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................................................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\MModule\eeprom_20080807-142739.B0E.bin Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Area: Firmware flash: 98004900000002:00D00900000000 Write: Firmware error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 error: error# 00000064 error: flash write error: 00102000:00002000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Fail Finished, time used: 390 sec Remove/Install battery now ! Also i full charged the battry before reset OR flash procedure. What is the problem . . . . Thankx in advance. |
my UB SHOW THIS ERROR HOW TO CLEAR THIS | SHIJILFONOTLY | Universalbox | 6 | 12-14-2008 13:36 |
Repair errom in K800.. but show this error... | bestncheap | Cruiser Suite | 4 | 10-11-2007 19:36 |
TST what is this ERROR check pls | club gsm | TST Dongle | 4 | 12-27-2005 13:50 |
