shripalkawdia | 01-30-2008 15:58 | spice s800 dead spice s800 problem = hang = after do this all opration phone dead
1st i make eeprom backup here log Code:
Initializing[6219:8A01]...
CPU: MT6219
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 89880F00010001:89880F00000000
flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Identification...
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
reading [eeprom]...
file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom_20080130-174541.B0E.bin
Finished, time used: 94 sec
Remove/Install battery now ! 2nd i read full flash here log Code:
Checking data, wait...
Action: read NOR flash
Boot...
Connecting, wait...
CPU: MT6219
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Identification...
.damaged firmware
.damaged hardware
reading [flash_part_1_of_1]...
file saved: C:\Program Files\InfinityBox\MModule\backup_flash_part_1_of_1_20080130-175505.B0X.bin
Finished, time used: 497 sec
Remove/Install battery now ! then i do format [whole flash chip ] here log Code:
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
Action: erase flash chip
Boot...
Connecting, wait...
CPU: MT6219
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Identification...
.damaged firmware
.damaged hardware
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Erase: chip 1 of 1
Write Done
Finished, time used: 166 sec
Remove/Install battery now ! then i want to flash phone with this file
Spice-S800_05A_V0.2_KAC161_Spice_En_2.14.A13_Oct-13-2006_En.B0M.bin loaded
but i got this error Code:
COM5 [VCP0] selected
Device: Spice S800
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom/ffs
Boot...
Connecting, wait...
CPU: MT6219
Boot Done
Initialize...
flash: 80008000800080:89888F00000000
flash: 92009200920092:89888F00000000
number of flash chip/regions detected: 00/01
Unknown or damaged flash chip, operation aborted.
Fault reasons:
1. damaged flash chip: replace or resolder/reball flash chip
2. damaged hardware: check hardware, water inside etc.
3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialize Fail
Finished, time used: 23 sec
Remove/Install battery now ! i do restore backup flash file
but i got this error massage
[data error]
Loading failed, probably damaged data file.
Languages: not detected
if flash chip damage ?
then why software make backup file ? |
