Old 01-30-2008, 15:58   #1 (permalink)
Member: 281925
Sonork: 100.113915
Thanks Meter: 63
spice s800 dead
spice s800 problem = hang = after do this all opration phone dead
1st i make eeprom backup here log
Initializing[6219:8A01]...
CPU: MT6219
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 89880F00010001:89880F00000000
flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Identification...
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
reading [eeprom]...
file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom_20080130-174541.B0E.bin
Finished, time used: 94 sec
Remove/Install battery now !
2nd i read full flash here log
Checking data, wait...
Action: read NOR flash
Boot...
Connecting, wait...
CPU: MT6219
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Identification...
.damaged firmware
.damaged hardware
reading [flash_part_1_of_1]...
file saved: C:\Program Files\InfinityBox\MModule\backup_flash_part_1_of_1_20080130-175505.B0X.bin
Finished, time used: 497 sec
then i do format [whole flash chip ] here log
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
Action: erase flash chip
Boot...
Connecting, wait...
CPU: MT6219
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Identification...
.damaged firmware
.damaged hardware
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Erase: chip 1 of 1
Write Done
Finished, time used: 166 sec
then i want to flash phone with this file
Spice-S800_05A_V0.2_KAC161_Spice_En_2.14.A13_Oct-13-2006_En.B0M.bin loaded
but i got this error
COM5 [VCP0] selected
Device: Spice S800
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom/ffs
Boot...
Connecting, wait...
CPU: MT6219
Boot Done
Initialize...
flash: 80008000800080:89888F00000000
flash: 92009200920092:89888F00000000
number of flash chip/regions detected: 00/01
Unknown or damaged flash chip, operation aborted.
Fault reasons:
1. damaged flash chip: replace or resolder/reball flash chip
2. damaged hardware: check hardware, water inside etc.
3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialize Fail
Finished, time used: 23 sec
i do restore backup flash file
but i got this error massage
[data error]
Loading failed, probably damaged data file.
Languages: not detected
if flash chip damage ?
then why software make backup file ?
Old 01-30-2008, 16:38   #2 (permalink)
te
Member: 2357
Thanks Meter: 4
Just look in log:
initially flash chip was detected correctly:
flash: 89:880F:00010001 : 89:880F:00000000 (it's correct Intel chip flash-id)
After some time flash chip detection is failed:
flash: 80008000800080:89888F00000000 (first line is not so good)
what to do:
charge phone batter completely (use another phone or expernal charger)
repeat flash process several times and see results.
if phone was buggy (hang) there is a chance that it was problems with hardware (f.e. flash chip soldered not good or damaged).
try to flash phone several times and post more logs here so it will be possible to understand what is the real reason of problem.
one more advice: rehot (or reball) flash chip.
Old 01-30-2008, 17:34   #3 (permalink)
Member: 281925
Sonork: 100.113915
Thanks Meter: 63
thx for repely with detail
need p supportor opinioun
bcoz
eeprom backup http://rapidshare.com/files/87830435...174541.B0E.rar
full flash backup http://rapidshare.com/files/87835640...175505.B0X.rar
Old 01-31-2008, 09:48   #4 (permalink)
Member: 281925
Sonork: 100.113915
Thanks Meter: 63
buzz....................
any body or p supportor there
Old 01-31-2008, 11:13   #5 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,397
@shripalkawdia
I can copy/paste text, but better I'll give you the link:
http:///vbb/showpo...05&postcount=2
Why you don't read and don't tried to follow advices ?
i-Pmart BX Series RJ45 Cable For Spice S800 For ET Box / Infinity Box / Vygis Box / B IPMART ipmart WebShop 0 05-15-2009 08:30
i-Pmart BX Series RJ45 Cable Compatible For Spice S800 For Infinity Box IPMART ipmart WebShop 0 03-14-2009 08:50
spice s800 restart when insart simcard rajtelecom Infinity-Box 5 07-31-2008 21:54
11/08/07 - ET-BoX v1.48 Released - Spice S800 Support Added .:ET-BoX.net:. ET-BoX 6 08-13-2007 09:52
05 Jan 2007: Spice S800 model supported InfinitySupport Infinity-Box 7 01-06-2007 16:26
Page generated in 0.27501 seconds with 8 queries
