Old 07-23-2008, 13:21   #1 (permalink)
rajtelecom's Avatar
Member: 446363
Sonork: 1577571:rajtelecom
Thanks Meter: 216
spice s800 restart when insart simcard
without simcard phone ok working
plz tall me what is problem in phone hardware or software
phone flash complet ok unlock ok but phone still same
COM3 [VCP0] selected
Device: Philips-S800
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: unlock
unlock method: standard
Boot...
19200 fixed
Connecting, wait...
Initializing[6219:8A01]...
CPU: MT6219
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 89880F00010001:89880F00000000
flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom]...
file saved: C:\Program Files\InfinityBox\MModule\eeprom_20080723-165448.B0E.bin
Backup required data Done
Patch required data...
detection procedure, wait...
detection procedure completed
Patch required data Done
Special operation...
Special operation Done
Write...
Write: eeprom
Write Done
Finalization...
Finalization Done
Finished, time used: 415 sec
Remove/Install battery now !
Old 07-23-2008, 13:51   #2 (permalink)
msmobile's Avatar
Member: 253882
Sonork: 100.1585698
Thanks Meter: 238
1st put no network sim n cheak if ph still restart then s-w problem flash the ph
if ph work ok then PA network ic
Old 07-23-2008, 19:39   #3 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
I Am Parsonally Suggest That, Why You Flashing Phone? It Is Chinesh Base Mt62xx Phone, And Solution Is First Format The Phone Safe Mode, If No Result Then Flash Phone And Format Complite Mode And Wright Imei. I Hope You Will Get Your Ans.
:dthank You
Good Luck.
Old 07-23-2008, 20:02   #4 (permalink)
Sam-TheMaster's Avatar
Member: 182895
Sonork: 100.112022
Thanks Meter: 541
@rajtelecom
Well. simple format is easy solution. and that will resolve your problem.
No need to play with flashing and etc.
Regards,
Sam
Old 07-24-2008, 22:17   #5 (permalink)
Member: 148515
Thanks Meter: 16,156
hello!
if phone without card is working good- then try to call 112.
if after 112 phone will restart- this is 100% hardware fault (power amplifier)
Old 07-31-2008, 20:54   #6 (permalink)
rajtelecom's Avatar
Member: 446363
Thanks Meter: 216
10x to all for reply
phone is hardware problem
from PA IC
spice s545 restart when sim is insert nitinkansara Infinity-Box 4 01-12-2009 16:14
Anycool D66+ restart when put simcard SGHGSM 3 Infinity-Box 1 10-15-2007 18:24
Anycool D66 restart when put simcard kurdistan Infinity-Box 1 09-23-2007 13:24
LG C3300 restart when u put SIMCARD .:[email protected]==:. LG 3 07-05-2007 14:20
05 Jan 2007: Spice S800 model supported InfinitySupport Infinity-Box 7 01-06-2007 15:26
Page generated in 0.29726 seconds with 8 queries
