01-15-2016, 21:53 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | Spd sc773x error read info/read flash/format [user report] I HAVE SELECT EVEN MANUALY LOADER STILL NOT WORKING SHOWING UNKNOWN STRUCTURE.. Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [1/15/2016 / 8:22:41 PM] Start at : [1/15/2016 / 8:22:58 PM] Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [1/15/2016 / 8:23:23 PM] Start at : [1/15/2016 / 8:24:05 PM] Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Boot Files missing! Select SLDR or PAC file! Boot failed! Reconnect Power/Cable! Finish at : [1/15/2016 / 8:24:14 PM] SLDR Load Ok BB CPU : SC7731 SC773x eMMc Loader v2.0 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [1/15/2016 / 8:26:24 PM] Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:17 Reconnect Power/Cable! Finish at : [1/15/2016 / 8:26:42 PM] Start at : [1/15/2016 / 8:26:53 PM] Operation : Read FullFlash [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:14 Reconnect Power/Cable! Finish at : [1/15/2016 / 8:27:07 PM] Start at : [1/15/2016 / 8:27:56 PM] Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:12 Reconnect Power/Cable! Finish at : [1/15/2016 / 8:28:08 PM] SLDR Load Ok BB CPU : SC7731 SC7731 eMMC UMS 4G512M v2 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [1/15/2016 / 8:29:56 PM] Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Finish at : [1/15/2016 / 8:30:08 PM] SLDR Load Ok BB CPU : SC7731 SC7731 eMMC 4G512M v1 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [1/15/2016 / 8:30:33 PM] Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Finish at : [1/15/2016 / 8:30:51 PM] SLDR Load Ok BB CPU : SC7731 SC7731 UMS 4G512M EC For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [1/15/2016 / 8:31:32 PM] Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [1/15/2016 / 8:31:46 PM] SLDR Load Ok BB CPU : SC7731 SC7731 UMS 4G512M EC For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [1/15/2016 / 8:32:27 PM] Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [1/15/2016 / 8:32:42 PM] SLDR Load Ok BB CPU : SC7731 SC773x eMMc Loader v2.0 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [1/15/2016 / 8:32:59 PM] Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:13 Reconnect Power/Cable! Finish at : [1/15/2016 / 8:33:12 PM] Start at : [1/15/2016 / 8:34:02 PM] Operation : Read NV [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:13 Reconnect Power/Cable! Finish at : [1/15/2016 / 8:34:15 PM] |
The Following User Says Thank You to johnoroo37 For This Useful Post: |
04-15-2016, 13:14 | #4 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: uk
Member: 372163 Status: Offline Thanks Meter: 57 | Quote:
