st 60 dead after flashing I unlock st60 succes, but after flashing main, lp map v. 29 phone dead. |
1 Attachment(s) Now I flash it v 0.46 & have only string on lcd. |
Check phone model, maybe is ST55, reflash for it, no risk. |
Hi, Pls, try to use v1.25 (old) from support area. If it will be not good results then pls read flash from this phone and send to me to analyze: [email protected] |
Infinity, I send You flash from st60 today morning, recive You it? |
Hi, Strange, but did not received you. Btw, did you tried to flash with v1.25 ? |
1.25 can,t flash it. ,, flash part1 error,, |
Hi, Could you, pls, post info from Log window (v1.25 flashing). But I think if two versions can't flash it correctly this means that phone has hardware problem (maybe partially damaged flash chip). |
1 Attachment(s) This log , maybi problem in cable prolific? |
Hi, Problem not in cabe for sure. I think it's need to reball (maybe change) flash chip. |
