05-02-2006, 18:22 | #2 (permalink) |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | what you mean???????? You wont software version or flash version? no software for this phones st55/st60 on infinity box with V1.25 & no version with flash also!!!!!!!!!!!! br Nabil |
05-02-2006, 18:58 | #3 (permalink) | |
All old versions was deleted from site long time ago. Use Q-Module instead of this old ST55/60 software. | |
05-02-2006, 18:58 | #4 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Paris, France Age: 45
Member: 45387 Status: Offline Thanks Meter: 53 | i need a software version not flash version look here http://forum.gsmhosting.com/vbb/show...highlight=st60 BR |
05-02-2006, 19:00 | #5 (permalink) | |
Member: 45387 Status: Offline Thanks Meter: 53 | Quote:
hello yes i used last version of qmodule always error at the beginning BR | |
05-02-2006, 20:36 | #6 (permalink) | |
My lovely link is: http://forum.gsmhosting.com/vbb/show...71&postcount=8 | |
05-02-2006, 21:25 | #7 (permalink) |
Member: 45387 Status: Offline Thanks Meter: 53 | ok sorry yesterday customer give me a dead st60 i've tryed to flash it with last Qmodule here is the log: COM1 selected Device: Siemens ST55,ST60 Checking data, wait... Action: Flash write Write: Firmware Write: Map/Customization Write: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Err: Boot failed: 3B Release Power button ! Err: wrong answer1 Boot Fail Finished Remove/Install battery now ! Time used: 27 sec BR |
05-02-2006, 22:16 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, No any connection. Possible reasons: wrong cable phone hardware damaged (connector or CPU or Flash/RAM) ST55/60 have to connect to software in any case even with totally empty/erased flash chip (of course if no HW problems). |
05-03-2006, 14:31 | #9 (permalink) |
Member: 45387 Status: Offline Thanks Meter: 53 | problem solved by heating CPU and FLASH CHIP and flashing with milano ''free soft'' so must use infinity V1.25 there is a bug in new version Qmodule because always same error thx BR |
05-03-2006, 15:26 | #10 (permalink) |
Member: 45387 Status: Offline Thanks Meter: 53 | after successfully flashed the phone with milano and the phone powerd on i've tryed second time with qmodule and it flashed it succesfully i dont understand!!!! the phone work perfectly. thx Log opened: [3/05/2006] [18:01:51] App: F:\Program Files\InfinityBox\QModule\QModule.exe [Infinity Box] v.2.11A Loading, wait... S/N: Wait... Current device: Panasonic GD55 Done Current device: Siemens ST55,ST60 Loading file [version 01]... ST60_029_Main_MJ2E.MIC.05M.bin Loaded Loading file [version 01]... ST60_029_Map_MJ2.MIC.O-MP.M04.12.05F.bin Loaded Loading file [version 01]... ST60_029_LP_MJ2.MIC-EMEA.L05.01_De_Fr_It_Du.05P.bin Loaded COM1 selected Device: Siemens ST55,ST60 Checking data, wait... Action: Flash write Write: Firmware Write: Map/Customization Write: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 04227E22212200 Flash: 00E3A000000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 area-02... area requested/selected: 02/02 Format file system Done Write... Write: Firmware area requested/selected: 01/01 Write: Map/Customization area requested/selected: 02/02 area requested/selected: 02/02 area requested/selected: 02/02 Write: Language Pack area requested/selected: 02/02 Write Done Finished Remove/Install battery now ! Time used: 1330 sec BR |
06-10-2006, 04:04 | #12 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | I'm using this pinout: 1,2,3=GND 5=TX 10=RX But i still can't connect with phone. The phone is locked, and i also try to flash a hanging ST55 and ST60. Already 5 phones but all can't connect. I'm using cable from my unibox, checked the pinout and its correct. Is the above pinout correct? Do it need some tuning? Thanks br, s1emens |
