Old 11-25-2008, 21:49   #1 (permalink)
Sudan-Mobiles's Avatar
Member: 281857
Thanks Meter: 214
STANDARD_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12 wanted 100 phone waiting ar lang
i need this fash file urgent ... couse i have 100 with arabic proplem . i download the 4 file from suport but just 1 power on fone without disply
here some information
newstar model x9988d
Old 11-25-2008, 22:18   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
have you tried these:
flashfiles/ChineseMiracle/_MT6225/STANDARD_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12_ Tintele-TT-N1_Black_16m_En_Ru_Fr_Es_It_De_Th_Vn_Tr_Farsi_Pt_A r.B0M.bin
[bin] flashfiles/ChineseMiracle/_MT6225/STANDARD_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12_ _Hyundai_MP880_Type_M619+_16m_En_Ru_Fr_Es_De_Cn_Tr _Pt_Ar.B0M.bin
[bin] flashfiles/Hyundai/MP880/Hyundai-MP880_Type_M619+_STANDARD_PCB01_GPRS_MT6225_S00.MA UI_GEMINI_W08_12_En_Ru_Fr_Es_De_Cn_Tr_Pt_Ar.B0M.bi n
Old 11-25-2008, 22:31   #3 (permalink)
Member: 281857
Thanks Meter: 214
yes all ..... one of them can make fone work but no disply ... i suggest i need full flash from working fone ....
Old 11-25-2008, 23:34   #4 (permalink)
Member: 281857
Thanks Meter: 214
hi infinityhelp i found same phone and i read full flash from it and flash it in phone so it work but not read sim card always insert sim (i think this from fone which i read ) can u fix this full flash if i uploud it ...
Old 11-26-2008, 00:25   #5 (permalink)
Member: 148515
hello!
try format phone
Old 11-26-2008, 08:19   #6 (permalink)
Member: 281857
Thanks Meter: 214
set dead after format
module v2.69
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:CD03:000B
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw 1: STANDARD_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12. BIN
ver. sw 2: MAUI.GEMINI.W08.12, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00AE0000
Detected eeprom/ffs address is non-standard: 00AE0000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address confirmed by user: 00AE0000
detecting eeprom/ffs size...
eeprom/ffs size: 00520000
ffs chip: 00
eeprom/ffs area: 00000000:00AE0000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 121 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 11-26-2008, 10:49   #7 (permalink)
Member: 281857
Thanks Meter: 214
infinity team what do you think about this :
i read full flash from working phone but insert sim card (with sim)
i made format but set dead
i read eeprom fro working fone after flash it phone alive but insert sim
what should i do ...and whats the problem is it from eeprom adress....?
Old 11-26-2008, 14:48   #8 (permalink)
Member: 281857
Thanks Meter: 214
i tryed to change language by language edit but no success . any one can share idea i am waiting and here is some pictures of phone ..
Old 11-26-2008, 19:36   #9 (permalink)
Member: 148515
Hello!
if format do not help- this means that this firmware is not suitable for this hardware.
Flash file with arabic from Exactly same model must be found.
Please tell us which problem did you get installing language by Lang editor.
maybe we can help from this side
Old 11-26-2008, 21:21   #10 (permalink)
Member: 281857
Thanks Meter: 214
ok ...the phones all ready contain arbic lang but with fault. some letters missing . i used lang editer to change arbic after read arbic dictionury from same working phone .all job went ok but after flash edited fullflash same error exist on fone(missing letters) ...... why this .... same phone only diferent is color poth contain arbic one fine without fualt ... why i cant repair it..
Old 11-26-2008, 22:27   #11 (permalink)
Member: 148515
hello!
I guess you need import>export fonts
Old 11-27-2008, 08:07   #12 (permalink)
Member: 281857
Thanks Meter: 214
hello!
i dont know do this .. more details pls
Old 11-27-2008, 09:17   #13 (permalink)
moecow's Avatar
Member: 264902
Thanks Meter: 12
hi frind am also have these probem and am looking for the correct flash
Old 11-27-2008, 09:26   #14 (permalink)
moecow's Avatar
Member: 264902
Thanks Meter: 12
wowowo i found the correct flash and it working perfct
Old 11-27-2008, 09:33   #15 (permalink)
Member: 281857
Thanks Meter: 214
what language on it ... is it accept sim card .. pls share this flash..
plz ineed this {STANDARD_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12 } amralkareem Infinity-Box 4 06-07-2009 11:13
flash[STANDARD_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12. BIN]_20080712-152118.B0M ceptel Infinity-Box 1 07-12-2008 13:55
C-100 please wait zakir375 Samsung Hardware Repair 8 03-31-2007 13:44
I want 100 logs motorolas , 100 logs sagem myx5, 100 logs panasonic gd87 cimeurop Wanted Products 2 01-31-2003 02:03
wanted 100 * 8210 screens .... max_gee Main Sales Section 6 09-05-2002 11:07
Page generated in 0.28397 seconds with 10 queries
