Old 04-22-2018, 13:56   #1 (permalink)
Member: 2681298
Thanks Meter: 3
Exclamation starlight madrid frp
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 25 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x05000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : LOCKED with CERT
Processing DA stage
Sending and initialize DA ...
[DA_ERROR] : 00007017
Boot Error!
Operation Failed
Elapsed: 00:00:08
Reconnect Power/Cable
help me plz
The Following User Says Thank You to nassim19 For This Useful Post:
Old 04-22-2018, 14:00   #2 (permalink)
Member: 2739340
Thanks Meter: 74
Hello your cpu solution is here check and post result
BB_CPU_PID : 6735
Link https://drive.google.com/open?id=1Ow...t6TZ57E29O82-4
The Following User Says Thank You to Oppo_Tool For This Useful Post:
Old 04-22-2018, 14:04   #3 (permalink)
Member: 2739340
Thanks Meter: 74
For mt6735 lock with cert check this and post result
https://drive.google.com/open?id=1gw...F5vfKVdCU4mvd-
Old 04-22-2018, 14:46   #4 (permalink)
Member: 2739340
Thanks Meter: 74
Wait for phone...
Phone found! [ 25 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:08
help me plz
Hello your problem solved or not
Old 04-22-2018, 17:23   #5 (permalink)
Member: 2681298
Thanks Meter: 3
not solved
Old 04-22-2018, 17:37   #6 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,102
test this
https://www.4shared.com/get/3qtE-pLe...A_SP_Test.html
The Following User Says Thank You to rebainoor For This Useful Post:
Old 04-22-2018, 18:03   #7 (permalink)
Member: 2739340
Thanks Meter: 74
not solved
Blank message never help always post logs after da file change what error comes to check
Old 04-22-2018, 18:41   #8 (permalink)
Member: 2681298
Thanks Meter: 3
Wait for phone...
Phone found! [ 26 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:08
Reconnect Power/Cable!
Old 04-22-2018, 20:08   #9 (permalink)
Member: 2739340
Thanks Meter: 74
Wait for phone...
Phone found! [ 26 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:08
Bro given you too file one is MT6735 and the other one is for lock with cert so post the other file logs also will try to check
Old 04-23-2018, 15:52   #10 (permalink)
CrKdz13's Avatar
Member: 111121
Sonork: 100.99340 : CrKdz13
Thanks Meter: 487
anyone with a working DA of this phone ?
WBR
The Following User Says Thank You to CrKdz13 For This Useful Post:
Old 05-13-2018, 15:14   #11 (permalink)
Member: 134586
Thanks Meter: 22
any new DA file for this phone
The Following User Says Thank You to hassenmob For This Useful Post:
Old 07-24-2018, 18:15   #12 (permalink)
Member: 2443309
Thanks Meter: 14
any new about starlight madrid frp
Old 09-11-2018, 12:33   #13 (permalink)
fethirx's Avatar
Member: 1480336
Sonork: 100.1606959
Thanks Meter: 76
https://www.youtube.com/watch?v=0won...ture=*********
The Following User Says Thank You to fethirx For This Useful Post:
Page generated in 0.21312 seconds with 8 queries
