starmobile jump hd sc7731 unable to read firmware i tick ldr mode still failed Card found: S/N : D7E808F4 , v0130 Chinese Miracle II [SPD module] v 1.15 Operation : Read FullFlash [ v1.15 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 58 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Unknown structure detected! Something went wrong :( If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:16 Reconnect Power/Cable! Card found: S/N : D7E808F4 , v0130 Chinese Miracle II [SPD module] v 1.14 Operation : Read FullFlash [ v1.14 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 58 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Unknown structure detected! Something went wrong :( If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:17 Reconnect Power/Cable! phone info http://i1064.photobucket.com/albums/.../jump%20hd.jpg phone still on my hand waiting on new update |
select SP Android 5.x as a boot. Also for read firmware for Android 5.x need root 1st. |
already do that still failed. br. |
Then no luck. Seek some similar PAC files, select them and try make read info. If it pass - then CM2 can handle it. Otherwise - not. Next time - open manual and read it. All explained. |
Dear Anynews for it I have one to reset user code but can't read info wih soft Code: Card found: S/N : 334FA6A3 , v0130 |
Hello. If you need just make reset - use "Reset in SVC" option and do Format FS. |
That HW type will be included in CM2SPD v1.20 |
Dear I have done as on document but not success I have selected sldr because on Models no Pac files where I can download pac file and what correct pac I need for Code: Card found: S/N : 334FA6A3 , v0130 |
Try to search on google to find .pac file or wait for next update. Br. Infinity Box Support Team. |
If anyone can share here Pac file its good for me if not then will wait next update Thanks |
Did you even try read my previous post??? http://forum.gsmhosting.com/vbb/11873191-post6.html |
thanks |
Ok, now explain it little bit more : What SW say in log? Does after powerOn there is green android appear? |
