Old 03-02-2016, 10:03   #1 (permalink)
dre2's Avatar
Member: 1190283
Thanks Meter: 61
starmobile jump hd sc7731 unable to read firmware
i tick ldr mode still failed
Card found: S/N : D7E808F4 , v0130
Chinese Miracle II [SPD module] v 1.15
Operation : Read FullFlash [ v1.15 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 58 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x eMMC v2.0 Loader Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Unknown structure detected! Something went wrong
If phone work normally - check correct selection (Model,FlashType)!
Elapsed: 00:00:16
Reconnect Power/Cable!
Chinese Miracle II [SPD module] v 1.14
Operation : Read FullFlash [ v1.14 ]
3. Insert cable
Phone found! [ 58 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Elapsed: 00:00:17
phone info
phone still on my hand waiting on new update
Old 03-02-2016, 10:06   #2 (permalink)
Member: 770503
Thanks Meter: 989
select SP Android 5.x as a boot.
Also for read firmware for Android 5.x need root 1st.
Old 03-02-2016, 10:13   #3 (permalink)
dre2's Avatar
Member: 1190283
Thanks Meter: 61
already do that still failed.
br.
Old 03-02-2016, 10:26   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 14,784
Then no luck. Seek some similar PAC files, select them and try make read info. If it pass - then CM2 can handle it. Otherwise - not.
Next time - open manual and read it. All explained.
The Following User Says Thank You to JayDi For This Useful Post:
Old 06-14-2016, 10:43   #5 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 445
Dear
Anynews for it
I have one to reset user code but can't read info wih soft
Card found: S/N : 334FA6A3 , v0130
Chinese Miracle II  [SPD module] v 1.19
Operation : Read PatternLock [ v1.19 ]
3. Insert cable
Phone found! [ 16 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Checking Structure ...
Unknown structure detected! Something went wrong :(
Check Correct model selection!!!
Elapsed: 00:00:29
Old 06-14-2016, 10:45   #6 (permalink)
JayDi's Avatar
Member: 462970
Hello.
If you need just make reset - use "Reset in SVC" option and do Format FS.
Old 06-14-2016, 12:21   #7 (permalink)
Rex
Member: 3468
Thanks Meter: 271
@Jaydi is right find similar PAC files
Old 06-14-2016, 13:34   #8 (permalink)
JayDi's Avatar
Member: 462970
That HW type will be included in CM2SPD v1.20
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 06-14-2016, 14:55   #9 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 445
Dear
I have done as on document but not success
I have selected sldr because on Models no Pac files
where I can download pac file and what correct pac I need for
SLDR Load Ok
BB CPU  : SC7731
SC773x eMMc Loader v2.0
For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab!
SLDR Load Ok
BB CPU  : SC7731
Nothing to do , select FlashFile!
SLDR Load Ok
BB CPU  : SC7731
Old 06-14-2016, 15:19   #10 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,860
Originally Posted by said4 View Post
Dear
SLDR Load Ok
BB CPU  : SC7731
SLDR Load Ok
BB CPU  : SC7731
SLDR Load Ok
BB CPU  : SC7731
Hello,
Try to search on google to find .pac file or wait for next update.
Br.
Infinity Box Support Team.
Old 06-14-2016, 15:58   #11 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 445
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
Thanks for your advice
If anyone can share here Pac file its good for me
if not then will wait next update
Thanks
Old 06-14-2016, 17:34   #12 (permalink)
JayDi's Avatar
Member: 462970
Did you even try read my previous post???
Old 06-15-2016, 07:22   #13 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 445
Yes of course but its hang on syn and nothing
thanks
Old 06-15-2016, 08:26   #14 (permalink)
JayDi's Avatar
Member: 462970
Ok, now explain it little bit more :
What SW say in log?
Does after powerOn there is green android appear?
Old 06-15-2016, 10:58   #15 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 445
Dear
here is log
No thing on screen
Page generated in 0.49349 seconds with 7 queries
