Old 01-24-2010, 12:39   #1 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 890
Still Dead After Complete Format
I have got one I-Phone Copy dead condition. I have full format it but still dead.
here is log.
COM6 [VCP0] selected
module v3.07
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:4703:0008
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC240200000000:18E59F00000000
flash: Samsung K5L2833ATA T 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.07, database date: 16.01.2010):
M5120_HRD_UI1_EN+FR+SP+PR+GR+GE+TU_128+32FLASH_A02 .BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: M5120_HRD_UI1_EN+FR+SP+PR+GR+GE+TU_128+32FLASH_A02 .BIN
project-id: M5120_HRD_UI1_EN+FR+SP+PR+GR+GE+TU_128+32FLASH_A02 , 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 1 min 21 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 01-24-2010, 14:27   #2 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Hello
Read full flash backup by ON phone then flash with read file & post here result......
before any oppration first read your dead phone backup file.......
Old 01-25-2010, 20:42   #3 (permalink)
Member: 148515
Thanks Meter: 15,716
hello!
try this one:
flashfiles/ChineseMiracle/_MT6205-MT6227/M5120_MD_EN+AR+BO+IN+RU+VI+TH+MA_128+32FLASH_A01_1 6m_En_Ru_Ml_Id_Th_Vn_Farsi_Ar.B0M.bin
zte gx 761 dead after complete formate neeraj1st Infinity-Box 5 08-20-2010 17:11
q380 dead after complete flash still dead bhoybits99 PadFinder box 1 12-21-2008 11:45
Spice S700 After complete Format FFS display is BLACK . amol_sm Infinity-Box 6 04-21-2008 17:58
anycool no network after complete format ffs sezief Infinity-Box 16 02-10-2008 13:30
C139.....still Dead After Complete Flashing. albarka network Infinity-Box 14 09-11-2006 20:18
Page generated in 0.24874 seconds with 8 queries
