03-28-2008, 22:07 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: Egypt
Member: 76228 Status: Offline Sonork: 113105 Thanks Meter: 22 | strang problem not with all chinese any idea for this strang problem |
03-29-2008, 01:21 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, To be honest it's quite hard to understand so so many words followed one by one without any dot or comma. Easy rules: 1. if software say "Press and HOLD..." it's good idea to press and HOLD phone button 2. if sofwate say "Release button" it's good idea to release buton |
03-29-2008, 21:04 | #3 (permalink) |
Member: 76228 Status: Offline Sonork: 113105 Thanks Meter: 22 | i know what you said i`m not new in this work try to understand me when softwear say release buton i do then phone stop booting i have to hold and press powe booton all the time to get phone pooting |
03-29-2008, 22:07 | #4 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | do u get this problem with all chinese phones? because i got this problem with one phone b4 and the problem was hardware [flash chip] i reheated it and the phone booted correctly after that. hope i have ben helpfule. P.S: sometimes setting lower baudrate is good idea. BR Mansi |
04-02-2008, 09:14 | #7 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 55
Member: 102467 Status: Offline Thanks Meter: 24 | hi pro now u see the error COM3 selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect error: boot phase#2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 4 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! |
04-02-2008, 09:25 | #8 (permalink) |
Member: 102467 Status: Offline Thanks Meter: 24 | now u see the probleme solved Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: Nokia N73(11) Software version: V2.0628.0.0.1" Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 353641015975117 Finished, time used: 53 sec Power off phone now ! COM1 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:94C1:CBCA high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.81F69322.[FS26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1.B IN_AEFFB3F9].rpl identification#1 detection finished device-id: 81F69322 identification#1 protocol ver: 04 ver. sw1: FS26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1.B IN ver. sw2: V2.0628.0.0.1, 064C0051 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _81F69322_FS26_05C_SET_PCB01_GPRS_MT6226_S01.V2_06 28_0_0_1.BIN_AEFFB3F9_20080401-161540.B0X.bin Finished, time used: 91 sec Remove/Install battery now ! COM1 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read eeprom Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:94C1:CBCA |
04-02-2008, 11:20 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 6205 is second MCU. (MCU_b) it has specific booting sequence. for example: you connected infinity box to second MCU pinout (tx_b, rx_b) so now, to get communication with it you must press power button and wait arround 1 minute (holding all time power button). this is because in a first place in this phone will start First MCU (MCU_a) after it started- you will see message "insert sim". Dont worry, still keep power button pressed. after some time program will detect second MCU and will start load boot file to phone. only after program will say "release button" you can release it. this procedure can be much more simple if you use "power_b" test point. by setting it to GND you make CPU2 boot imidiatly no even need to press power i hope i answered your question about little strange boot sequence of second MCU. if not- ask more detailed |
Strange Problem Not soloved yet 2008.. | adnanskyland | HWK | 1 | 07-11-2008 17:19 |
strange problem ever with sony ericsson v630i user code can`t reset | ServiceTEL | Universalbox | 0 | 04-19-2008 10:47 |
Strange problem with MYX5-2T not all networks are working after unlock with sws-sag | lobalt | ARM9 BASED M62 / M62+ | 11 | 11-22-2005 00:47 |
Strange problem with MYX5 not all networks are working after unlock with sws-sag | lobalt | ARM9 BASED M62 / M62+ | 8 | 06-20-2005 21:53 |
