aslamahmed | 03-12-2010 11:12 | Strange 6300 dead: Dual Firmware yesterday I received china phone from customer in fault of restart, i formatted the set but problem couldn't be solved so i flashed it with the same firmware i downloaded from servers there were 4 identical firmware but the software erases and writes firmware 2 times for 2 flash chips here are the logs step by step:
First I formatted: Code:
==== [3/11/2010 2:52:01 PM] ====
COM4 [Serial2] selected
module v3.10
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:6276:7649
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22022201:2AEA0000000000
flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
otp offset: 00000000
detecting chip #01 in region #00...
flash: 01227E22022201:4CBDD000000000
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
number of flash chip/regions detected: 02/01
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B_W09_08_MP_V2.BIN
project-id: MAUI.08B.W09.08.MP.V2, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 2 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 01
ffs/eeprom area: 00800000:00600000-007FFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B_W09_08_MP_V2__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B_W09_08_MP_V2__ffs_20100311-145336.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 2 min 13 sec
Remove/Install battery now !
Then i wrote firmware from support and set became dead: Code:
==== [3/11/2010 7:21:34 PM] ====
module v3.10
Action: write flash
"smart write" active
write: Firmware
HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B_W09_08_MP_V2__6300i_16m_En_Ru_Fr_Tr_Farsi_Pt_Ar.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
Code CRC check error fix...
firmware do not have "Code CRC check error" area
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
error: write operation failed
Write Fail
Finished, time used: 51 sec
erased whole chip: Code:
==== [3/11/2010 7:33:45 PM] ====
module v3.10
Action: erase whole flash chip
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
flash: 01227E22022201:C6F23C00000000
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
ffs/eeprom chip: 01
====> Write ...
Write Done
chip formatting...
Erase: chip 1 of 2
Erase: chip 2 of 2
Finalization Done
Finished, time used: 2 min 40 sec
flashed again with another identical firmware from support but still same: Code:
module v3.10
Action: write flash
write: Firmware
HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B_W09_08_MP_V2_16m_En_Ru_Fr_Tr_Pt_Ar.B0M.bin
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
flash: 01227E22022201:FFFFFF00000000
Initialize Done
====> Set baud ...
460800
Set baud Done
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
====> Write ...
- damaged firmware
ffs/eeprom address can not be detected, value from database assigned: 00000000/00000000
Area: Firmware
Write: Firmware
jump to next chip: 01
Write: Firmware
Write Done set is still dead any help, suggestion will be appeitiated.
Waiting for reply.
Thanks. |
