Old 03-12-2010, 11:12   #1 (permalink)
Member: 383929
Thanks Meter: 10
Strange 6300 dead: Dual Firmware
yesterday I received china phone from customer in fault of restart, i formatted the set but problem couldn't be solved so i flashed it with the same firmware i downloaded from servers there were 4 identical firmware but the software erases and writes firmware 2 times for 2 flash chips here are the logs step by step:
First I formatted:
==== [3/11/2010 2:52:01 PM] ====
COM4 [Serial2] selected
module  v3.10
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
ffs/eeprom backup enabled, it may takes several minutes !
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:6276:7649
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 01227E22022201:2AEA0000000000
flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
otp offset: 00000000
detecting chip #01 in region #00...
flash: 01227E22022201:4CBDD000000000
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
====>  Set baud ...
460800
Set baud Done
====>  Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
number of flash chip/regions detected: 02/01
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B_W09_08_MP_V2.BIN
project-id: MAUI.08B.W09.08.MP.V2, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 2 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 01
ffs/eeprom area: 00800000:00600000-007FFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B_W09_08_MP_V2__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B_W09_08_MP_V2__ffs_20100311-145336.B0E.bin
Backup required data Done
====>  Patch required data ...
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write Done
====>  Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 2 min 13 sec
Remove/Install battery now !
Then i wrote firmware from support and set became dead:
==== [3/11/2010 7:21:34 PM] ====
module  v3.10
Action: write flash
"smart write" active
write: Firmware
HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B_W09_08_MP_V2__6300i_16m_En_Ru_Fr_Tr_Farsi_Pt_Ar.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
Initialize Done
====>  Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
Code CRC check error fix...
firmware do not have "Code CRC check error" area
====>  Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
error: write operation failed
Write Fail
Finished, time used: 51 sec
erased whole chip:
==== [3/11/2010 7:33:45 PM] ====
module  v3.10
Action: erase whole flash chip
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
flash: 01227E22022201:C6F23C00000000
Initialize Done
====>  Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
ffs/eeprom chip: 01
====>  Write ...
Write Done
chip formatting...
Erase: chip 1 of 2
Erase: chip 2 of 2
Finalization Done
Finished, time used: 2 min 40 sec
flashed again with another identical firmware from support but still same:
module  v3.10
Action: write flash
write: Firmware
HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B_W09_08_MP_V2_16m_En_Ru_Fr_Tr_Pt_Ar.B0M.bin
skip: Customization
skip: Eeprom/ffs
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
flash: 01227E22022201:FFFFFF00000000
Initialize Done
====>  Set baud ...
460800
Set baud Done
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
====>  Write ...
- damaged firmware
ffs/eeprom address can not be detected, value from database assigned: 00000000/00000000
Area: Firmware
Write: Firmware
jump to next chip: 01
Write: Firmware
Write Done
set is still dead any help, suggestion will be appeitiated.
Waiting for reply.
Thanks.
Old 03-12-2010, 12:01   #2 (permalink)
Member: 148515
Thanks Meter: 14,899
hello!
better if you try every flash file from support.
also try FFS file
you can try to make format FFS complete after each flashing
and for sure check battery voltgae, it should be more than 3,7 volts
Old 03-12-2010, 15:40   #3 (permalink)
Member: 383929
Thanks Meter: 10
thanks for quick response.
i already have tried every identical files from support server and also each time i format ffs after flashing but still same condition i have never seen a set with 2 firmware writing could u please explain this. Also i have checked battery voltage and tried with external power supply with 4.6 voltage.
Old 03-12-2010, 18:47   #4 (permalink)
Member: 148515
hello!
sorry, in your logs i see only one firmware.
which firmware you call as "second" ?
Old 03-16-2010, 16:37   #5 (permalink)
Member: 383929
Thanks Meter: 10
of course there is only one firmware but this is one is written twice. look
Area: Firmware
Write: Firmware
Write: Firmware
thanks 4 ur response but i returned the phone to customer.
Old 03-16-2010, 17:06   #6 (permalink)
=GsM_Angel='s Avatar
Member: 1062107
Thanks Meter: 544
Area: Firmware
Write: Firmware
Write: Firmware
did you returned the Phone to the *******r already dead? how sad.... does Infinity can find some more solution about this......
Old 03-17-2010, 15:15   #7 (permalink)
Member: 383929
Thanks Meter: 10
yup i returned the set to customer might be it was a hardware problem... anyways infinity support is marvelous in many ways.....
6300 new dual sim pinout find by me khurram_player Infinity-Box 8 04-01-2010 14:28
6300 NEW dual sim INVALID sim ok 100% working themobileshop Infinity-Box 1 09-09-2009 19:30
6300 new dual sim full flash and epprom for infinity support gul_hassan528 Infinity-Box 1 06-27-2009 20:01
strange problem whit update firmware raltelefonica FuriousGold 3 11-23-2008 09:57
Nokia 6300 Cannot Update Firmware Zerosleep Nokia Hardware & Hardware Repair 8 01-20-2008 07:30
Page generated in 0.37513 seconds with 8 queries
